- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- linear encoder + cia402 driver + delta a2 incremental
- Sakhalin_Cat
- Thank you received: 7
05 Oct 2023 12:01 - 05 Oct 2023 12:03 #282356
by Sakhalin_Cat
Replied by Sakhalin_Cat on topic linear encoder + cia402 driver + delta a2 incremental
0x2102 post=265395 userid=22009It is well documented for the Delta A3 drives but not for the A2.
Delta documentation for A2 full closed loop on my site - argon.pw/Files/DEN_IA_ASD_A2_Full-Closed...n_AN_EN_20200316.pdf
Last edit: 05 Oct 2023 12:03 by Sakhalin_Cat.
The following user(s) said Thank You: mehdidadash
- mehdidadash
- Thank you received: 4
05 Oct 2023 12:05 #282357
by mehdidadash
Replied by mehdidadash on topic linear encoder + cia402 driver + delta a2 incremental
Yes it has some errors and missing features.
There is a pdo for Digital outputs in a3 but not for a2.
- Beovoxo
- Thank you received: 30
18 Feb 2026 18:47 - 18 Feb 2026 18:48 #343159
by Beovoxo
Replied by Beovoxo on topic linear encoder + cia402 driver + delta a2 incremental
Last edit: 18 Feb 2026 18:48 by Beovoxo.
- ts
25 Mar 2026 10:00 #344704
by ts
Replied by ts on topic linear encoder + cia402 driver + delta a2 incremental
I have worked configuration for this, if it is actually question.
I connected aux encoder 1u resoluution to aux to drive. Connected it to hal by xml config, named linear-pos.
And change actual position to linear-pos. And its works.
About points to 1 rotation - i connected to drive, and calculate gear ratio, on my case it was 1.4 - you put electronic gear 1:1 and move 1 rotation of motor, and look at measurement "clocks" what is movement on mm. And calculate. Also coefficient in my case for linear aux was 7000 . There are manual from delta for calculation.
Also important point that i put in xml file in linuxcnc (lcec some.xml) electronic gear values, and every load of linuxcnc it download by ethercat .
- EtherCAT
Time to create page: 0.182 seconds
