RTEC1616 IO board, how to configure?
- leexi
12 Apr 2023 18:36 - 12 Apr 2023 18:44 #268919
by leexi
RTEC1616 IO board, how to configure? was created by leexi
Dear Folks
I been using linuxcnc 2.8.4 on pentium asus PC with ECT86 from Tellligent ethercat stepper driver and works great just when I power on drive on linuxcnc screen always make a few mm movement I do not know way
and now I purchased a RTEC1616 ethercat IO card from Tellligent, but I can not make it run, I been seen a video on utube and seems is working but I do not have any clue about how to make it work, .XML missing file?
Is there any one that can help me?
thank you
Xi
thank you
Xi
Last edit: 12 Apr 2023 18:44 by leexi.
- Thank you received: 4128
12 Apr 2023 23:44 #268950
Replied by rodw on topic RTEC1616 IO board, how to configure?
You just need to add the correct XML to you ethercat config file
Here is how I set mine up with the ECT86 drives
github.com/rodw-au/linuxcnc-cia402/blob/...hercat-conf.xml#L158
The following user(s) said Thank You: leexi
Time to create page: 0.295 seconds
