Leadshine io module and encoder module cannot enter OP mode correctly
3 years 6 months ago #269731 by whatawhiz
Thank you very much for your help.
Now I have mapped all the output PDOs in the XML configuration file. The encoder input module is already functioning properly. Unfortunately, the other two IO modules still cannot function properly.
I also checked the ESI file I found online and tried using sii_write to write the bin file converted by siitool, but it still doesn't work. After restarting the module, there will still be many unnecessary mappings when outputting PDOs.
3 years 6 months ago #269732 by whatawhiz
Thank you very much. My previous configuration file for the servo drive was written based on the configuration files from you and dbraun1981. They have helped me a lot.
3 years 6 months ago #269733 by whatawhiz
I'm giving up tinkering with this mess for now. Buying second-hand goods at a low price resulted in wasting more than ten hours searching for information everywhere, but it still couldn't be used. It's really a sad story.
 I have ordered a set of Delta R1 series IO modules, just hope there won't be such strange issues anymore.
 I'll paste the XML configuration file and the ESI file I found below. Hopefully, they can help those who encounter such problems in the future.
Warning: Spoiler!
File Name: debug.txt
File Size:1.73 KB
File Name: EM32DI-E4_...neon.xml
File Size:44.51 KB
File Name: EM32DO-E4_..._new.xml
File Size:38.81 KB
3 years 6 months ago #269751 by rodw
Did you list the sdos? Maybe something there needs to be set.
Having documentation is a blessing!
Don't talk to me about second hand I/Os. I bought some beckhoff io module from another forum  user I have not tested yet. But when i looked, the xml for them was only about 10 lines...
Good luck!
You keep the IO modules and send me the encoder modules :)
Time to create page: 0.486 seconds
