Need help creating "Initcmd.xml" from Twincat config!
16 Jun 2023 12:50 - 21 Jun 2023 07:07 #273692 by akg1904
I am trying to create an "Initcmd.xml" file for an IO module.
I generated the device description xml file using TwinCAT 3.
Now I am stuck! I am not able to figure out what to map out of all of the initcmds present in the exported xml.
I have attached my device description xml file here.
I hope somebody can help me regarding this.
Thanks and Regards
Abhishek
Last edit: 21 Jun 2023 07:07 by akg1904.
03 Nov 2023 14:54 - 03 Nov 2023 14:56 #284460 by panming
hello,Is your problem solved? I'm having the same problem as you
Last edit: 03 Nov 2023 14:56 by panming.
16 Nov 2023 12:48 #285615 by akg1904
hi,
So basically the way Igh Ethercat master works is that it reads from sii memory of slave for configuration and odot's sii memory is blank.Connect odot with twincat and extract the proper sii data that has to be written and then use
ethercat sii_write command to upload it onto odot's sii memory. I don't remember how to extract this .bin file in TwinCAT top of my mind but it is fairly simple. Also one clue I had come across the solution by reading dmesg log error (some incomplete config something). search for that in google too.
cheers!!
17 Nov 2023 07:55 #285704 by panming
hello,
I've looked at the EEPROM of the coupler and it's almost blank except for the vendor information at the beginning. I tried to burn the manufacturer's ESI (i.e. xml file) into eeprom, but nothing changed. Can you recall how to extract the bin file? or give a Google keyword.
thanks.
17 Nov 2023 10:59 #285727 by rodw
I found twincat totally useless. I just use ethercat pdos and save to a text file.
then write the xml. we've done a couple of no name IO modules and a servo drive that way.
The following user(s) said Thank You: tiagounderground
17 Nov 2023 11:06 #285729 by panming
Hi.rodw
Your point is correct, provided that the "EtherCAT PDO" can correctly recognize the PDO, I have configured a board IO module, and his PDO is complete. But I'm on my pluggable coupler and there's no feedback. I'm thinking about how to manually map PDOs, but because I've been in the hospital lately, there's no way to experiment with some of my ideas.
28 Nov 2023 07:06 #286666 by akg1904
Sorry I don't remember much of it.
But I think it should be in Ethercat Tab -> Advance Setting.
there are multiple of setting which you can look into
Regards
Abhishek
08 Dec 2023 22:43 - 08 Dec 2023 22:45 #287593 by tiagounderground
Replied by tiagounderground on topic Need help creating "Initcmd.xml" from Twincat config!
Hi.rodw
do you have a tutorial on this?
Last edit: 08 Dec 2023 22:45 by tiagounderground. Reason: mention an user
Time to create page: 0.096 seconds
