Need help creating "Initcmd.xml" from Twincat config!
3 years 4 months ago - 3 years 4 months ago #273692 by akg1904
I am trying to create an "Initcmd.xml" file for an IO module.
I generated the device description xml file using TwinCAT 3.
Now I am stuck! I am not able to figure out what to map out of all of the initcmds present in the exported xml.
I have attached my device description xml file here.
I hope somebody can help me regarding this.
Thanks and Regards
Abhishek
Last edit: 3 years 4 months ago by akg1904.
2 years 11 months ago - 2 years 11 months ago #284460 by panming
hello,Is your problem solved? I'm having the same problem as you
Last edit: 2 years 11 months ago by panming.
2 years 11 months ago #285615 by akg1904
hi,
So basically the way Igh Ethercat master works is that it reads from sii memory of slave for configuration and odot's sii memory is blank.Connect odot with twincat and extract the proper sii data that has to be written and then use
ethercat sii_write command to upload it onto odot's sii memory. I don't remember how to extract this .bin file in TwinCAT top of my mind but it is fairly simple. Also one clue I had come across the solution by reading dmesg log error (some incomplete config something). search for that in google too.
cheers!!
2 years 11 months ago #285704 by panming
hello,
I've looked at the EEPROM of the coupler and it's almost blank except for the vendor information at the beginning. I tried to burn the manufacturer's ESI (i.e. xml file) into eeprom, but nothing changed. Can you recall how to extract the bin file? or give a Google keyword.
thanks.
2 years 11 months ago #285727 by rodw
I found twincat totally useless. I just use ethercat pdos and save to a text file.
then write the xml. we've done a couple of no name IO modules and a servo drive that way.
The following user(s) said Thank You: tiagounderground
2 years 11 months ago #285729 by panming
Hi.rodw
Your point is correct, provided that the "EtherCAT PDO" can correctly recognize the PDO, I have configured a board IO module, and his PDO is complete. But I'm on my pluggable coupler and there's no feedback. I'm thinking about how to manually map PDOs, but because I've been in the hospital lately, there's no way to experiment with some of my ideas.
Time to create page: 0.250 seconds
