beckhoff modules not working
  • Goodwood
  • Goodwood's Avatar Topic Author
  • New Member
  • New Member
09 Sep 2023 21:02 #280350 by Goodwood
beckhoff modules not working was created by Goodwood
Hi, I'm having trouble getting recognition of some beckhoff modules(KL1408,KL2408,KL9010) I bought on eBay. I bought the EK 1100 from a separate seller. The  EK 1100 is picked up with ” ~ $ ethercat slaves” as are the sigma7 drives. I've never used beckhoff modules before and am not sure how to tell what the problem is. The EK 1100 could be malfunctioning. All or some of the modules could be malfunctioning. Is it necessary to have the KL9010 on the end to have all modules show as slaves.Of the four LEDs on the EK 1100, the top left is permanently on the bottom right is flashing and the other two are off is that the normal state you would expect from an EK 1100 at recognition. Any help would be greatly appreciated.
09 Sep 2023 21:47 #280352 by db1981
Replied by db1981 on topic beckhoff modules not working
KLXXXX are not Ethercat Modules, this is older K-Bus (own Beckhoff) .
this are not usable with ethercat couplers (EK1100 etc.... )
You need ELXXXX Cards.
The following user(s) said Thank You: endian
  • Goodwood
  • New Member
  • New Member
10 Sep 2023 08:04 #280381 by Goodwood
Replied by Goodwood on topic beckhoff modules not working
Thanks for your quick and concise reply! Is it right that the EL xxxx do not need a special end - justst a plastic cover?
Time to create page: 0.092 seconds
