- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- search for EtherCat slaves mini io board 24V dc
- bkt
- Thank you received: 114
01 Oct 2023 16:31 #281996
by bkt
search for EtherCat slaves mini io board 24V dc was created by bkt
As title post, I search for a very little slaves board like 40x40mm with 4 or 6 digital input, 2 or 4 digital output and one analogue input ....there are a lot of ardeuino based board but too mutch and too big for my request ..... so I ask if anyone knows of any such small slave components or any project ...
thanks on advances for any suggest
- Hakan
- Thank you received: 453
01 Oct 2023 19:33 - 01 Oct 2023 19:35 #282017
by Hakan
Replied by Hakan on topic search for EtherCat slaves mini io board 24V dc
If it just had been the digital I/O you could get by with a LAN9252 in digital i/o mode (no MCU needed). But with the analog input, you need something to deliver the analog value to the LAN9252 such as a MCU. A single LAN9255 should in theory be able to do it. It should be possible to squeeze onto 40x40 mm, but I don't know of any such project.
Last edit: 01 Oct 2023 19:35 by Hakan.
- Thank you received: 4128
02 Oct 2023 03:15 #282041
Replied by rodw on topic search for EtherCat slaves mini io board 24V dc
Small: www.aliexpress.com/item/1005004740047192.html
This one has everything www.aliexpress.com/item/1005004377766525.html
Its very hard to find an affordable I/O board with analog and even more so an encoder. But this one does it!
- bkt
02 Oct 2023 05:55 #282044
by bkt
Replied by bkt on topic search for EtherCat slaves mini io board 24V dc
thanks but for cabinet io ethercat I know a lot of item and test more than 10 model ... perhaps all quite ok .... but now my intention is find somethings very little to insert near limit switch in a very small spaces .... like 40mm x 40mm x 20mm more or less .... so some boardf socket instead rj45 soket for example seem better ... or soldering ethercat connection can be a solution .... these for explain better how little can be these board ...
- pippin88
- Thank you received: 51
02 Oct 2023 10:23 #282059
by pippin88
Replied by pippin88 on topic search for EtherCat slaves mini io board 24V dc
I had the exact same thought.
A small ethercat IO board to be located on the machine, for example on Z axis - could have limit switch, probe input etc.
Then only need one or two network cables. Ready made network cables are easily available and cheap.
But I could not find a board like this.
Even 8 IO ethercat boards are large and expensive.
- bkt
02 Oct 2023 15:54 #282070
by bkt
i see some experiment on hackaday.io ..... but I hope someone have to produce it not as experiment only ....
03 Oct 2023 05:51 #282126
Another option is to use PoE (power over ethernet) to provide power for IO.
Beckhoff have servos that include 3 phase power and ethercat signals in the one cable.
So your small I/O boards may not even be necessary
A lot of ethercat servo and stepper drivers have I/O built in for min,max and home sensors. Ideally they would be used in conjunction with a custom homing module so homing and limit errors ocurrs in the drive itself. One day I will try that. If you used 220v servos, you could easilly place the drives beside the motors and also add a small 24 v power supply for the IO beside it.I had the exact same thought.
- bkt
03 Oct 2023 16:18 #282172
by bkt
He rodw, thanks .... but i know well all ac integrated drive and backhoff drive (not all product for sure).... for europe for example Axor product but many other .... but really need a custom little board for very small place for 2 or 3 input and 2 or 3 output 1 analogue if possible .... was for insert a little push button in small place and drive a little led as user signaling .... but have a very little spaces and very little hole for wiring (max 6mm diameter) so 2x0,22 for power 24V dc + 4wire ethercat is max i can use .... unfortunately.
03 Oct 2023 21:55 #282218
See if you can do something with this www.mikroe.com/ethercat-click
The following user(s) said Thank You: bkt
- EtherCAT
Time to create page: 0.137 seconds
