asd-a2-e ... lcec driver?
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Oct 2023 16:29 - 04 Oct 2023 17:31 #282075 by bkt
*********************** advice about deasda driver  before to read all post *****************************
lcec_deasda driver admit to work only in Cyclic synchronous velocity mode --- NO OTHER MODE ---
Hello to everyone .... never use asd-a2-e drive from delta .... so I set driver parameter to P01-1 to "C" for ethercat cia402 ... than try to read data using terminal command "ethercat slaves" .... but responding is only long 32 bit data instead of producer name .... plus if try to start Axis Gui I have an error on corresponding lcec.0.3.xx pin .... I have 3 drive from other brand and 1 delta asd-a2-e drive .... I see there are a specific drive on src/lcec forlder into github .... so question was: need to use a specific drive or specific xml config istead generc one for asd-a2-e- delta drive? cia402 PDO's not was the usual?
If someone can share some link about linuxcnc+ethercat+asd-a2-e setting was good enought.
real thanks in advances
Last edit: 04 Oct 2023 17:31 by bkt.
  • Moderator
  • Moderator
02 Oct 2023 17:30 #282086 by tommylight
Replied by tommylight on topic asd-a2-e ... lcec driver?
Moved to "EtherCAT" section.
The following user(s) said Thank You: bkt
  • bkt
  • Platinum Member
  • Platinum Member
02 Oct 2023 19:45 #282091 by bkt
Replied by bkt on topic asd-a2-e ... lcec driver?
sorry I made a mistake I thought I was inside the ethercat section ....
  • Moderator
  • Moderator
02 Oct 2023 20:21 #282092 by tommylight
No worries, you are welcomed here, always.
Thank you for your continued support, it is much appreciated.
02 Oct 2023 21:37 #282095 by Hakan
Replied by Hakan on topic asd-a2-e ... lcec driver?
Search here in the forum for this servo driver. It needed some special treatment if I rekember right.
  • bkt
  • Platinum Member
  • Platinum Member
03 Oct 2023 05:43 #282125 by bkt
was first thing search on google and in forum too .... maybe serch in wrong manner .... because find something about asd-b3-e .... but nothing related to a2-e ..... or nothing of relevant. Maybe language was the problem ... so I ask help ....
03 Oct 2023 07:02 #282132 by Hakan
It was the thread with asd-b3-e I was thinking about. Maybe, just maybe, the same need to be done for the asd-a2-e driver.
03 Oct 2023 14:45 - 03 Oct 2023 14:58 #282162 by jjdege
Replied by jjdege on topic asd-a2-e ... lcec driver?
hi bkt
try this link github.com/liuzq71/LinuxCNC-ASDA-A2-E
it worked for me
there are the parameters to insert into the servo and if you want to give the name Asda A2E there is also the Delta-asda.bin file with the procedure on how to do it
HI
Last edit: 03 Oct 2023 14:58 by jjdege.
  • bkt
  • Platinum Member
  • Platinum Member
03 Oct 2023 16:41 - 03 Oct 2023 16:45 #282175 by bkt
so with ASDA-soft can read parameter inside ASDA-A2-E Servo_Ethercat.par right?
But why delta not make a manual with parameter list so no need too effort? ... any how seems to see panasonic drive ... a lot of parameter ... probabily too mutch.
what is siitool used for? I understand that once the correct parameters have been loaded with ASDA-soft then theoretically I could use "generic drive" instead of "lcec_deasda" drive... is this correct?
siitool was only for write correct name and obtain correct response from ethercat slave command?
Last edit: 03 Oct 2023 16:45 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
03 Oct 2023 16:43 #282176 by bkt
I see now synapticon .... good guys
Time to create page: 0.092 seconds
