- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- lcec_conf: ERROR: couldn't allocate user/RT shared memory
- MakerYang
- Thank you received: 17
13 Oct 2023 07:27 #282872
by MakerYang
lcec_conf: ERROR: couldn't allocate user/RT shared memory was created by MakerYang
I encountered a problem when using EtherCAT.
ERROR:
ERROR:
root@armcnc:~/linuxcnc/script# sudo -u armcnc linuxcnc /opt/armcnc/configs/ethercat_xyz/machine.ini
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/opt/armcnc/configs/ethercat_xyz'
Machine configuration file is 'machine.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./machine.hal
creating ladder-state
rtapi_shmem_new failed due to shmget(key=0xacb572c7): Permission denied
./machine.hal:12: waitpid failed lcec_conf lcec_conf
./machine.hal:12: lcec_conf exited without becoming ready
LinuxCNC terminated with an error. You can find more information in the log:
/home/armcnc/linuxcnc_debug.txt
and
/home/armcnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminalLinux armcnc 4.14.87 #5 SMP PREEMPT RT Wed Sep 13 15:15:26 CST 2023 aarch64 GNU/Linuxroot@armcnc:~/linuxcnc/script# ethercat master
Master0
Phase: Idle
Active: no
Slaves: 3
Ethernet devices:
Main: 00:11:22:f2:b2:95 (attached)
Link: UP
Tx frames: 17582
Tx bytes: 1074888
Rx frames: 17581
Rx bytes: 1074828
Tx errors: 0
Tx frame rate [1/s]: 125 125 114
Tx rate [KByte/s]: 7.3 7.3 6.7
Rx frame rate [1/s]: 125 125 114
Rx rate [KByte/s]: 7.3 7.3 6.7
Common:
Tx frames: 17582
Tx bytes: 1074888
Rx frames: 17581
Rx bytes: 1074828
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: Slave 0
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000root@armcnc:~/linuxcnc/script# ethercat slaves
0 0:0 PREOP + ECR60(COE)
1 0:1 PREOP + ECR60(COE)
2 0:2 PREOP + ECR60(COE)root@armcnc:~/linuxcnc/script# ethercat cstruct
/* Master 0, Slave 0, "ECR60"
* Vendor ID: 0x00000a88
* Product code: 0x0a880001
* Revision number: 0x00000202
ec_pdo_entry_info_t slave_0_pdo_entries[] = {
{0x6040, 0x00, 16}, /* Control Word */
{0x6060, 0x00, 8}, /* ModeOfOperation */
{0x607a, 0x00, 32}, /* Profile Target Position */
{0x6041, 0x00, 16}, /* Status Word */
{0x6061, 0x00, 8}, /* Modes of Operation display */
{0x6064, 0x00, 32}, /* Position Actual Value */
{0x60fd, 0x00, 32}, /* Digital Inputs */
ec_pdo_info_t slave_0_pdos[] = {
{0x1600, 3, slave_0_pdo_entries + 0}, /* Receive PDO 1 */
{0x1a00, 4, slave_0_pdo_entries + 3}, /* Transmit PDO 1 */
ec_sync_info_t slave_0_syncs[] = {
{0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE},
{1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE},
{2, EC_DIR_OUTPUT, 1, slave_0_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_0_pdos + 1, EC_WD_DISABLE},
{0xff}
/* Master 0, Slave 1, "ECR60"
ec_pdo_entry_info_t slave_1_pdo_entries[] = {
ec_pdo_info_t slave_1_pdos[] = {
{0x1600, 3, slave_1_pdo_entries + 0}, /* Receive PDO 1 */
{0x1a00, 4, slave_1_pdo_entries + 3}, /* Transmit PDO 1 */
ec_sync_info_t slave_1_syncs[] = {
{2, EC_DIR_OUTPUT, 1, slave_1_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_1_pdos + 1, EC_WD_DISABLE},
{0xff}
/* Master 0, Slave 2, "ECR60"
ec_pdo_entry_info_t slave_2_pdo_entries[] = {
ec_pdo_info_t slave_2_pdos[] = {
{0x1600, 3, slave_2_pdo_entries + 0}, /* Receive PDO 1 */
{0x1a00, 4, slave_2_pdo_entries + 3}, /* Transmit PDO 1 */
ec_sync_info_t slave_2_syncs[] = {
{2, EC_DIR_OUTPUT, 1, slave_2_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_2_pdos + 1, EC_WD_DISABLE},
{0xff}
};Please Log in or Create an account to join the conversation.
- MakerYang
13 Oct 2023 08:01 #282873
by MakerYang
Replied by MakerYang on topic lcec_conf: ERROR: couldn't allocate user/RT shared memory
I tried restarting the device and found that the error message has changed.
root@armcnc:~# sudo -u armcnc linuxcnc /opt/armcnc/configs/ethercat_xyz/machine.ini
lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefined symbol: ecrt_slave_config_sdo
./machine.hal:14: waitpid failed /usr/bin/rtapi_app lcec
./machine.hal:14: /usr/bin/rtapi_app exited without becoming ready
./machine.hal:14: insmod for lcec failed, returned -1
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
and
as well as in the output of the shell command 'dmesg' and in the terminalPlease Log in or Create an account to join the conversation.
- MakerYang
13 Oct 2023 09:05 #282877
by MakerYang
I have consulted some references and learned about this old script, which can solve the above problem.
realtime.mk
github.com/abausano/linuxcnc-ethercat/tree/master
realtime.mk
- Thank you received: 4149
13 Oct 2023 09:51 #282878
Replied by rodw on topic lcec_conf: ERROR: couldn't allocate user/RT shared memory
A couple of things
1. This repo of mine should compile and create a deb file of the linuxcnc-ethercat driver.
github.com/rodw-au/linuxcnc-ethercat
I had a bit of help here from one of the ethercat developers.
I did this so I could package it for AMD64 and host it. Then the repositories are preinstalled in my installer in the installing linuxcnc section here (as a sticky). forum.linuxcnc.org/9-installing-linuxcnc...or-linuxcnc-x86-only
I have thought of building it for the pi4 and hosting it too.
It should compile on ARM, Please let me now if it does.
2. The ethercat guys now have a repository and support the Raspberry Pi, Please open the spoilers for details here
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The following user(s) said Thank You: MakerYang
- MakerYang
13 Oct 2023 10:46 #282884
by MakerYang
I am trying to build a deb based on github.com/rodw-au/linuxcnc-ethercat. I will notify you if it works. However, the chip on my development board is not quite the same as the Raspberry Pi, but it should be usable.
- MakerYang
13 Oct 2023 10:55 #282885
by MakerYang
I have successfully built the DEB files based on github.com/rodw-au/linuxcnc-ethercat, resulting in two DEB files. Do I need to install them both?
drwxr-xr-x 7 root root 4096 Oct 13 18:52 linuxcnc-ethercat
-rw-r--r-- 1 root root 15714 Oct 13 18:53 linuxcnc-ethercat_0.9.4_arm64.buildinfo
-rw-r--r-- 1 root root 2926 Oct 13 18:53 linuxcnc-ethercat_0.9.4_arm64.changes
-rw-r--r-- 1 root root 63936 Oct 13 18:53 linuxcnc-ethercat_0.9.4_arm64.deb
-rw-r--r-- 1 root root 679 Oct 13 18:52 linuxcnc-ethercat_0.9.4.dsc
-rw-r--r-- 1 root root 95408 Oct 13 18:52 linuxcnc-ethercat_0.9.4.tar.xz
-rw-r--r-- 1 root root 159592 Oct 13 18:53 linuxcnc-ethercat-dbgsym_0.9.4_arm64.debPlease Log in or Create an account to join the conversation.
- MakerYang
13 Oct 2023 12:03 #282888
by MakerYang
I have placed the two compiled deb files at mirrors.geekros.com/pool/main/focal/. They are linuxcnc-ethercat-dbgsym_0.9.4_arm64.deb and linuxcnc-ethercat_0.9.4_arm64.deb. You can directly download them and migrate to your own software repository if needed.
I haven't tested it on the Raspberry Pi yet. Below is the information of my current device, which in theory should be universally compatible.
root@armcnc:~# uname -a
Linux armcnc 4.14.87 #5 SMP PREEMPT RT Wed Sep 13 15:15:26 CST 2023 aarch64 GNU/Linuxroot@armcnc:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
- bkt
- Thank you received: 114
14 Oct 2023 09:13 - 14 Oct 2023 09:15 #282969
by bkt
Replied by bkt on topic lcec_conf: ERROR: couldn't allocate user/RT shared memory
I see your dmesg ..... you are sure your xml is right? .... because I obtain same error in same situation where xml is not clear ... like a lot of comment .... seems parser not able to show all error and exception so show something .... that is real better than show nothing .... after these good luck with your installation and work.... but take my worlds only like a warning messages ... i'm not an expert.
Last edit: 14 Oct 2023 09:15 by bkt.
14 Oct 2023 10:35 #282978
Great work!
this deb: linuxcnc-ethercat-dbgsym_0.9.4_arm64.deb
contains the debug symbols so its not required for normal operation.
- MakerYang
14 Oct 2023 10:41 #282980
by MakerYang
I have resolved this issue. It was a mismatch between the configuration in the XML file and the EtherCat being used. I reviewed the product manual and have successfully run it on both the XZ and XYZ models. However, I still find the relationship between these configurations not very clear, so I need to continue learning and experimenting. I have placed the relevant configurations in the repository at
github.com/armcnc/linuxcnc/tree/main/debian/opt/armcnc/configs
I'm not entirely sure if there is any documentation in the LinuxCNC documentation regarding HAL and XML configurations related to EtherCat. It could be that I'm not very accustomed to the LinuxCNC documentation, which might have caused me to overlook them.
- EtherCAT
Time to create page: 1.854 seconds
