Ethercat - Failed to register PDO entry: No such file or directory
  • Nalesque
  • Nalesque's Avatar Topic Author
  • New Member
  • New Member
18 Oct 2023 14:02 #283235 by Nalesque
Hello everyone,
I am currently trying to configure an EasyIO board from www.bausano.net/en/hardware/easyio.html which is an ethercat board with analog and digital IO.
I followed the Rodw post: forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step to install needed tools and the tutorial HERE to build my XML file (in attachment).
By the way, thank you very much to them and all the ethercat contributors for all their work.
Now the problem: when I try to load my config, I get this debug info:
Debug file information:
Note: Using POSIX realtime
LCEC: master 0 PDO entry registration failed
lcec: rtapi_app_main: Invalid argument (-22)
./hallib/ethercat.hal:2: waitpid failed /usr/bin/rtapi_app lcec
./hallib/ethercat.hal:2: /usr/bin/rtapi_app exited without becoming ready
./hallib/ethercat.hal:2: insmod for lcec failed, returned -1
144345
Stopping realtime threads
Unloading hal components
I do not understand the "failed to register PDO entry", is it a rights problem? Maybe I forgot to install something?
ethercat master
gives me:
Master0
  Phase: Idle
  Active: no
  Slaves: 1
  Ethernet devices:
    Main: 00:25:b3:76:73:71 (attached)
      Link: UP
      Tx frames:   307404
      Tx bytes:    18444272
      Rx frames:   307402
      Rx bytes:    18444152
      Tx errors:   0
      Tx frame rate [1/s]:    117    116    116
      Tx rate [KByte/s]:      6.9    6.8    6.8
      Rx frame rate [1/s]:    117    116    116
      Rx rate [KByte/s]:      6.9    6.8    6.8
    Common:
      Tx frames:   362877
      Tx bytes:    21772668
      Rx frames:   362873
      Rx bytes:    21772428
      Lost frames: 4
      Loss rate [1/s]:          0      0      0
      Frame loss [%]:         0.0    0.0    0.0
  Distributed clocks:
    Reference clock:   Slave 0
    DC reference time: 0
    Application time:  0
                       2000-01-01 00:00:00.000000000
Do you have an idea about that? Pretty sure it is a silly mistake...
Thank you all
Regards
18 Oct 2023 15:22 - 18 Oct 2023 16:49 #283239 by jjdege
HI
<syncManager idx="0" dir="out/in">
out or in must have sequential numbering
Regards
File Name: ethercat-c...0-18.xml
File Size:5 KB
Last edit: 18 Oct 2023 16:49 by jjdege.
The following user(s) said Thank You: Nalesque
  • Nalesque
  • New Member
  • New Member
18 Oct 2023 19:49 #283249 by Nalesque
Hi jjdege,
Thank you for your answer, indeed the problem was the numbering.
I wanted so much to organize the IO that I did not noticed it, I feel silly now :)
Are you satisfied with the EasyIO board?
The following user(s) said Thank You: jjdege
18 Oct 2023 21:16 #283254 by jjdege
Hi Nalesque
I purchased and configured the EasyIO, not used yet, I use the FR4000 step/dir in EtherCAT, I'm switching to Delta servos and the EasyIO will be necessary for the cnc.
I'll tell you if it works
I think the analog in/out pins work with float and s32, I have to do some tests
  • Nalesque
  • New Member
  • New Member
18 Oct 2023 21:40 #283257 by Nalesque
Well, I am currently trying to make the thing work...
In HALShow, EasyIO is online, oper and state is op, but IO does not react when I change state...
I'll let you know if I find out.
For the analog, I switched to float and did not revert
19 Oct 2023 06:44 #283274 by jjdege
Hi Nalesque
I attach the xml file, tested and ok
I have tested the analog pins and they work two ways, s32 and float
with a value of 33000 from 9.95V
File Name: ethercat-c...0-19.xml
File Size:4 KB
  • Nalesque
  • New Member
  • New Member
19 Oct 2023 20:06 #283316 by Nalesque
Hi !
Thank you for your tests and infos.
I realized that I'm stupid tired when I finally figured out that if the EasyIO communication was working but not the IO it is because I forgot to power the 24V Field of the board ! Now everything works perfectly :D
Thank you jjdege
27 Oct 2023 18:35 #283913 by eduard
Hi, I bought an EasyCAT fo ardino any trying to communicate with LCNC.
I made the ethercat-conf.xml file what is attached below. On HALshow I see the pins, but I'm not able to communicate with the board with the test rig, what I also bought for the test.
May I ask for some help with it?
ethercat master
linuxcnc@m5:~$ ethercat master
Master0
  Phase: Operation
  Active: yes
  Slaves: 4
  Ethernet devices:
    Main: ac:87:a3:02:1f:77 (attached)
      Link: UP
      Tx frames:   449734
      Tx bytes:    29443638
      Rx frames:   449733
      Rx bytes:    29443562
      Tx errors:   0
      Tx frame rate [1/s]:   1000   1000    998
      Tx rate [KByte/s]:     65.1   65.2   65.0
      Rx frame rate [1/s]:   1000   1000    998
      Rx rate [KByte/s]:     65.1   65.2   65.0
    Common:
      Tx frames:   449734
      Tx bytes:    29443638
      Rx frames:   449733
      Rx bytes:    29443562
      Lost frames: 0
  Distributed clocks:
    DC reference time: 751746277851565000
    Application time:  751746643058053959
                       2023-10-27 18:30:43.058053959
ethercat slaves
linuxcnc@m5:~$ ethercat slaves
0  0:0  OP     +  EK1100 EtherCAT-Koppler (2A E-Bus)
1  0:1  OP     +  EL1008 8K. Dig. Eingang 24V, 3ms
2  0:2  OP     +  EL2008-0015 8K. Dig. Ausgang 24V DC, 0.35A, nicht kurzschlussfe
3  0:3  PREOP  +  Generic 32+32 bytes rev 1
27 Oct 2023 20:12 - 27 Oct 2023 20:42 #283914 by jjdege
HI
I get an error in the .xml file
with the modified file, LCNC sees the pins,
test if the devices are op
Attachment not found
Last edit: 27 Oct 2023 20:42 by jjdege.
27 Oct 2023 21:12 #283921 by eduard
Thanks, I'll correct it, but I'm pretty sure it is not the problem, since I commented complety out this part for testing.
Any other suggestion?
What arduino code shloud I use? Now I testing whith this code from examples: TestEasyCAT.ino
Time to create page: 0.202 seconds
