Absolute Encoders - Homing & Backlash
- marq_torque
- Thank you received: 3
04 Dec 2023 07:25 #287171
by marq_torque
Absolute Encoders - Homing & Backlash was created by marq_torque
Hello Everyone,
I have searched throughout the forum but not finding any example for Ethercat servo with absolute Encoders Integrated with linuxcnc. Can anyone share any example?
Another question is how do we incorporate backlash with absolute Encoders??
Thanks much appreciated in advance.
- Thank you received: 4149
04 Dec 2023 10:08 - 04 Dec 2023 10:09 #287177
Replied by rodw on topic Absolute Encoders - Homing & Backlash
I don't think there will be anything specific that will be needed. The encoder count may be a 64 bit number but I beleive that is supported in Hal with 2.9.1. Worst case, you might need to read 2 x 32 bit values and cobine them in a component. Jusr read up on the hal data type
In my config which you can find here github.com/rodw-au/linuxcnc-cia402
I just connect the feedback as follows.
net 0-pos-fb => joint.0.motor-pos-fb <= cia402.0.pos-fb
but this is not an absolute encoder.
Last edit: 04 Dec 2023 10:09 by rodw.
The following user(s) said Thank You: marq_torque
- onceloved
- Thank you received: 59
08 Dec 2023 13:32 #287531
by onceloved
Replied by onceloved on topic Absolute Encoders - Homing & Backlash
I am using an ethercat absolute servo motor and everything is working fine. If you can please send me your configuration and I will modify it for you.
- onceloved
08 Dec 2023 13:34 #287532
by onceloved
HOME_ABSOLUTE_ENCODER = 0 | 1 | 2 - Used to indicate the joint uses an absolute encoder. At a request for homing, the current joint value is set to the HOME_OFFSET value. If the HOME_ABSOLUTE_ENCODER setting is 1, the machine makes the usual final move to the HOME value. If the HOME_ABSOLUTE_ENCODER setting is 2, no final move is made.
- marq_torque
11 Feb 2024 18:31 #293103
by marq_torque
Replied by marq_torque on topic Absolute Encoders - Homing & Backlash
Thanks RODW for suggesting, I'm not understanding how to configure parameters as per drives I'm using but still I'll give a try.
Thanks a Lot
Thanks a Lot
- marq_torque
11 Feb 2024 18:33 #293104
by marq_torque
Sorry for late reply, Thanks for your support, I'm sending files from laptop in while. I'll try what RODW suggested. If you have any specific Panasonic A6B configuration help, it is really helpful.
Thanks a lot
Thanks a lot
Time to create page: 0.245 seconds
