Problems integrating EtherCAT and LinuxCNC
- smal
- Thank you received: 4
14 Dec 2023 15:34 #288132
by smal
Problems integrating EtherCAT and LinuxCNC was created by smal
I would like to make LinuxCNC work with my EK1100 and subsequent EL1809 and EL2008 modules.
For that I have installed EtherCAT following this instructions:
forum.linuxcnc.org/ethercat/45336-etherc...step-by-step?start=0 (#237098)
and the functionality works according to my expectations. I can see the modules:
smal@linuxCNC:~/linuxcnc-ethercat$ ethercat slaves
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL1809 16K. Dig. Eingang 24V, 3ms
2 0:2 PREOP + EL2008 8K. Dig. Ausgang 24V, 0.5A
and the EtherCAT communication is running as soon Linux Bookworm 12.1 is active.
Thank you very much to Rod Webster for his work done here.
Now I would like to integrate EtherCAT modules to my LinuxCNC project. For the start I have included:
loadusr -W /bin/lcec_conf ethercat-conf.xml
loadrt lcec
into my hal file. When I start my LinuxCNC project I get following message:
Note: Using POSIX realtime
lcec: dlopen: /home/smal/linuxcnc-dev/rtlib/lcec.so: cannot open shared object file: No such file or directory
./smal3D_CNC_machine.hal:20: waitpid failed /home/smal/linuxcnc-dev/bin/rtapi_app lcec
./smal3D_CNC_machine.hal:20: /home/smal/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./smal3D_CNC_machine.hal:20: insmod for lcec failed, returned -1
I assume a part of EtherCAT driver should be added to LinuxCNC and then recompiled which was not done with EtherCAT installation. I already have an /linuxcnc-ethercat folder on my home folder but when I try it to recompile I get the message:
mal@linuxCNC:~/linuxcnc-ethercat$ make
configure.mk:8: *** halcompile/comp executable not found or set. Stop.
make: *** [Makefile:17: config.mk] Error 2
I have also tried this way - Ethercat build from source - full instructions (#277900):
forum.linuxcnc.org/ethercat/49771-etherc...instructions?start=0
but while trying to get code from repositories:
smal@linuxCNC:~$ git clone gitlab.com/etherlab.org/ethercat.git ethercat-master
fatal: repository 'gitlab.com/etherlab.org/ethercat.git' does not exist
smal@linuxCNC:~$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
fatal: repository 'github.com/LinuxCNC/linuxcnc.git' does not exist
What to do to get the missing /home/smal/linuxcnc-dev/rtlib/lcec.so file or what to do to get the things done properly?
loadrt lcec
- TimP
- Thank you received: 9
14 Dec 2023 17:52 #288144
by TimP
Replied by TimP on topic Problems integrating EtherCAT and LinuxCNC
have you tried?
loadusr -W lcec_conf ethercat-conf.xml
instead of
instead of
The following user(s) said Thank You: smal
- smal
14 Dec 2023 21:21 #288169
by smal
Replied by smal on topic Problems integrating EtherCAT and LinuxCNC
With
instead of
I get the same error:
When I grep for lcec_conf I found it in smal@linuxCNC:/bin$
In this folder is no lcec to be found. Anyway why there is a problem when I try to recompile the linuxcnc-ethercat? I guess I should be able to compile my own lcec.so and in worst case put it in linuxcnc-dev/rtlib/ folder manually.
instead of
- smal
14 Dec 2023 21:42 #288172
by smal
Problem solved:
I have found the lcec.so file in this folder:
/usr/lib/linuxcnc/modules/lcec.so
and the I have copied to this folder:
Reference post: Beckhoff ethercat 64 with bit linuxcnc, How to install.(#123873)
forum.linuxcnc.org/ethercat/35591-beckho...-to-install?start=10
After that there was a problem finding ethercat-conf.xml. As you proposed it should be: loadusr -W lcec_conf ethercat-conf.xml
Now my linuxcnc loads without problems and I hope to be able to add nets to I/O pins.
- Thank you received: 4149
15 Dec 2023 08:35 #288201
Replied by rodw on topic Problems integrating EtherCAT and LinuxCNC
Sorry you had some issues here. There have been a few changes. I'm not sure if the linuxcnc installer has been updated to the 2.9.1a patch but.
1. The ethercat guys now have their own repository
2. They also started to hosted the Linuxcnc ethercat driver in that repository.
3. The 2.9.1 installer already has the ethercat repositories installed
4. There is therefore no need to compile anything from source to get ethercat installed
You simply need to type
Then continue with my sticky instructions in the sticky you linked to.
You should not have issues being unable to find the .so file because it is installed in the correct system folder and it should be in the search path. I'm not sure what happened there. Maybe its not being set properly by the installer.
sudo apt update
sudo apt install ethercat-master libethercat-dev linuxcnc-ethercatThen continue with my sticky instructions in the sticky you linked to.
15 Dec 2023 08:49 #288203
EDIT:
to permananetly add the modules folder to your path you can edit .bashrc in your home folder and add this at the end. (geany .bashrc)
export PATH="/usr/lib/linuxcnc/modules:$PATH"
But it should resolve when running linuxcnc as all of the standard components live there too.
Time to create page: 0.081 seconds
