Ethercat, EL6751 and CANOpen
1 year 9 months ago - 1 year 9 months ago #318235 by endian
Replied by endian on topic Ethercat, EL6751 and CANOpen
I did everything in the twincat 3 from the beginning... All stuff have to be visible and workable via local PDO setup... then I active configuration on the local PC with right scan time... for us should be a 1ms which U have to define in the PLC tasks...then rebuild them and active configuration but you have to upload PDOs configuration in the Process datas section... if is everything green means OK and you should disconnect it from the Twincat3 PC and plug it to the debian ethercat master rj45 socket.... then command
ethercat pdos
and you have to see active configuration in the EL6751 master ...
take care about the shape of the PDOs because they are different from the shape of twinCAT3 PDO configuration then you have to export startup in the Startup section .. export them to excel as .csv and then copy paste it in to the ethercat-conf.xml file with "complete" config definition just copy paste them in front of SM managers and if you have luck and no syntax issues you made everything should work from first shot... I do not experiment with different setup and legacy setup, it is there because of very old stuff which should use little bit different shape of communication datas or protocol..check files in the attachements for a hint
if nothing helps you should run command
lcec_configgen
which will create you a working PDOs config of your acual stuff in the el6xxx master
I will check your file tomorrow because I am currently busy with my configuration too..
regards...
Last edit: 1 year 9 months ago by endian. Reason: FORGOR THE CONFIG
1 year 9 months ago #318242 by mic
Replied by mic on topic Ethercat, EL6751 and CANOpen
That´s the best instruction i´ve seen so far!
following your steps:
- Configuring everything in twincat and make it OP
- Switching to lcnc running "ethercat pdos" and map everything
- exporting SDOs
-> everything works - thank you so much, i´ll share my config when it´s finished!
1 year 9 months ago #318452 by endian
Send me .esi files for canOpen devices from your config... there are not supported startup SDO and it can not be generated automaticly ...
1 year 3 weeks ago #336034 by Marko6
Replied by Marko6 on topic Ethercat, EL6751 and CANOpen
Greetings from the Czech Republic!
I'm working on a spindle (IMT 40kRPM) and the drive only has CAN, so I decided to use the EL6751, because everything else on my machine is on Ethercat. That's the problem.
There is a possibility that the CAN is running from TwinCAT and I can spin motor, etc. If I then connect the EK1100 to the LinuxCNC network, both cards start up (OP), but the CAN is red (flashing in the attached configuration, otherwise still red). Any idea what's wrong with that? Did I miss something?
Thank you. Best regards,
Pavel.
1 year 3 weeks ago - 1 year 3 weeks ago #336052 by endian
1. Turn off AoE
2. Timing ... 4ms your config != 1ms is your lcec master
3. Refclock cycles has to be something negative as "-1"
Here is working config of the sewlteb from my machine...
Last edit: 1 year 3 weeks ago by endian.
1 year 3 weeks ago #336275 by Marko6
Thanks. It works now.
However I have spindle.0 and spindle.1 and as soon as I added spindle.1, spindle0 stopped working (Linuxcnc - Qtdragon only sends the setpoint.0 value and no enable signal). Strange.
Time to create page: 0.408 seconds
