Ethercat, EL6751 and CANOpen
- endian
- Thank you received: 134
11 Oct 2025 12:07 #336276
by endian
Replied by endian on topic Ethercat, EL6751 and CANOpen
Upload your config ... I can check it.. more detail as ..Thanks. It works now.
However I have spindle.0 and spindle.1 and as soon as I added spindle.1, spindle0 stopped working (Linuxcnc - Qtdragon only sends the setpoint.0 value and no enable signal). Strange.
- Marko6
11 Oct 2025 14:00 #336277
by Marko6
Replied by Marko6 on topic Ethercat, EL6751 and CANOpen
Thanks for a help, I am not big pro in Linuxcnc.
Spindle.0 is Delta C2000 and ethercat card running in Velocity mode. So I made comp file that sending enable signal to it and the rest is usuall cia402.
Spindle.1 is SD2S via CoE.
If I have just one spindle.0 its running well. Then if I add spindle.1 it runs well but spindle.0 receive just setpoint without enable word.
- endian
13 Oct 2025 03:39 #336360
by endian
okay ... thats kind weird ..
it should not runs like you described ...
maybe help convert setpoint to bool and there will be signal enable ... or use some general enable to enable spindle.0 too
