Ethercat, EL6751 and CANOpen
- rammfr
04 Nov 2024 20:11 #313777
by rammfr
Replied by rammfr on topic Ethercat, EL6751 and CANOpen
Hi endian, Thanks for your answers. I'll try to follow your advices. Another question: How do I setup the SDOs. Do you have some hints for me?
BR Franz
BR Franz
- endian
- Thank you received: 134
04 Nov 2024 20:45 #313779
by endian
Replied by endian on topic Ethercat, EL6751 and CANOpen
Yes I have had done it ... I will post them tomorrow ... Take an inspiration from them there will be a ET200B from siemens, keb f5 vfd and kollmorgen s343... But... I am out of shop today .. family stuff
Regards
Regards
The following user(s) said Thank You: rammfr
- endian
05 Nov 2024 16:59 - 06 Nov 2024 19:25 #313830
by endian
here they are, take a look... component is not finished yet... I will upload them when I will have an update ...
.xml config are only for this configuration... but it is clearly vissible how it works... where what is and timing are very important
setup from my attachments has about 330us scan time on profibus which are less then 1ms for lcnc default scan time period ... there are 4 slaves
Last edit: 06 Nov 2024 19:25 by endian.
- rammfr
10 Nov 2024 11:34 #314182
by rammfr
Unfortunately I get a Config error, when trying to use the startup SDO stuff.
Here the error in Twincat, obviously via ethercat xml I get a similar one (SDO download 0x8000 (58 bytes9 aborted
'Klemme 4 (EL6731)' (1004) 'PS': CoE ('InitDown' 0x8000:00) - SDO Abort ('Value range of parameter exceeded (only for write access).', 0x06090030): 'EL67xx CoE Init Cmd 3 (8000:00)'.
BR Franz
BR Franz
- endian
10 Nov 2024 13:21 #314185
by endian
Cau you share your twincat3 project ... Which stuff you need to run? I can check it and create working configuration of ethercat-conf.xml...
That should be more helpful then writing a tons of posts...
- rammfr
10 Nov 2024 18:40 - 10 Nov 2024 18:45 #314199
by rammfr
Wow, this would be great!Here are 2 projects:
In the end I do want a ethercat config for 4 servostar axis, ids 11,12,13,14
BR Franz
- profibus_latest was working without any SDOs, see ethercat-config from my previous posted project. But here I do have the described timing issues.
- profibus_mit_startup is the thing I tried today. I do not get a working sdo config... I simply exported 'startup' of the el6731 in Twincat as csv, then I added the sdos to the ethercat config.
BR Franz
Last edit: 10 Nov 2024 18:45 by rammfr.
- endian
12 Nov 2024 20:38 - 13 Nov 2024 14:16 #314341
by endian
this is dry setup...You ve done them in tc build 4026.60 and I have 4024.59 and downloading yours... you do not use a legacy mapping but that else? why?tomorrow I check them live on my koppler and will exact customize mapping if it does not work... dmesg -v me with ethercat debug 1regards
Last edit: 13 Nov 2024 14:16 by endian.
- rammfr
13 Nov 2024 09:37 #314370
by rammfr
Thanks a lot. I'll have a try as soon as possible.
If I understand your question right: I do use the MDP mapping (not the legacy) since I thought that then I do not need any SDO configuration in the ethercat conf, all the startup stuff is then stored at the EL6731 itself -- but I just followed some advice in this Forum, clearly I do not know what's really happening.
BR Franz
BR Franz
- endian
13 Nov 2024 13:28 #314374
by endian
i think you are little bit wrong because of mapping... mapping is used to setup communication canal to shape which you need...
you can use legacy or mdp but there will be different temps for your program.. if you will use MDP, my profibus component will not work probably... I had to check them... but for setup purposes of communication start it is OK
but all of them will need SDOs which tells the slave how to communicate with its master ...
- rammfr
23 Nov 2024 15:38 #315113
by rammfr
Hello Endian,after a lot of atempts, I am still not able to work with the servostar drives via profibus. I think I incorporated all of your hints (use of legacy mapping, sdo stuff) but unfortunately I does not work.Please, have a look. Thanks in advance, Franz
Time to create page: 0.327 seconds
