EtherCAT Servo cannot set to OP state
10 Feb 2024 09:01 #292980 by Stean
Replied by Stean on topic EtherCAT Servo cannot set to OP state
I confirm, I have the same servo and this configuration works.
23 Apr 2025 08:01 #326937 by emresensoy
Replied by emresensoy on topic EtherCAT Servo cannot set to OP state
I have similiar problem with this,
My configuraton has 1 VEICHI sd700 servo drive and 1 8I 8O digital IO card,
IO card working no problem,
Servo drive's encoder position is also working, I can see the encoder pos value changesĀ  when control is not enabled and I turn the motor by myself
But when I enable machine, servo drive not goes to enable state,
could you please help to me?
23 Apr 2025 08:18 #326940 by Hakan
Replied by Hakan on topic EtherCAT Servo cannot set to OP state
It is obviously a cia402 drive.
Download and install the cia402 component.
See an example config here
github.com/dbraun1981/hal-cia402
23 Apr 2025 09:04 #326941 by emresensoy
with my current configuration I can make the drive ethercat OP state ,
and Ican track absolute encoder values,
with cia402, drive not goes to ethercat OP state, stay preop
23 Apr 2025 10:14 #326946 by Hakan
Then there is some other config error.
The drive should go to OP if you use cia402 or not. cia402 works in ethercat OP only, not in PREOP or INIT or any other,
so it should go to OP regardless if you use cia402 or not.
Can you post your hal file when using cia402?
23 Apr 2025 11:10 #326953 by emresensoy
Thank you mr Hakan,
I added them,
23 Apr 2025 12:12 #326956 by emresensoy
- Solved -
There is a startup sequence in control word,
set bit number 1 2, 0 to 1
then if you set bit 3, drive goes to enabled state,
Thanks a lot
23 Apr 2025 16:11 #326965 by Hakan
What did I do :) ?
23 Apr 2025 17:41 #326971 by emresensoy
nothing but something:D
Time to create page: 0.131 seconds
