Raspberry Pi 5 EtherCAT master servo thread period
  • zmrdko
  • zmrdko's Avatar Topic Author
  • Elite Member
  • Elite Member
12 Feb 2024 15:22 - 12 Feb 2024 15:31 #293152 by zmrdko
i would like to share some research findings.
I have acquired RPi 5 since I wanted to check linuxcnc performance on this new single board PC.
The performance leap compared to RPi 4 is staggering. I tried to hook up Delta B3 EtherCAT drives, which was pretty straight-forward.
Browsing youtube for linuxcnc ethercat videos I come across this one:
So I thought that I should try this on raspberry pi 5. 125000ns was too much, but 250000ns was mostly OK.
But with this cycle times, servo drives started to have troubles with getting to OP mode.
Guys at etherlab found out, that ethercat master driver generic (DEVICE_MODULES="generic") is only good for 1000000ns threads/cycle time.
To reach better cycle times, I was told to try "genet" driver wich is working fine on Raspberry Pi 4. (RPi5 and RPi4 has the same ethernet chip BCM54213PE)
But the final verdict is, that RPi5 uses macb driver (Cadence GEM) and not genet.
Thats why we are stuck with generic device module.
Link to etherlab issue thread:
gitlab.com/etherlab.org/ethercat/-/issues/104
Last edit: 12 Feb 2024 15:31 by zmrdko. Reason: formatting
The following user(s) said Thank You: CORBETT
12 Feb 2024 16:44 #293154 by 0x2102
Install ethtool and run this in Terminal:
sudo apt install ethtool
ip a
sudo ethtool -c "NIC CARD NAME" and post your output.
In essence you are trying reduce the settings (buffer) as much as you can.
You can change the settings with:
sudo ethtool -C "NIC CARD NAME" "NEW SETTING".
Some drivers allow to reduce to 0, some others require a higher minimum number.
  • zmrdko
  • Elite Member
  • Elite Member
12 Feb 2024 18:22 #293157 by zmrdko
Hi!
thanks for reply.
see output in attachment
12 Feb 2024 19:00 #293161 by rodw
Regarding Bjarnes comments on your issue about debian could you advise if you are using the image on the Downloads page?
12 Feb 2024 21:04 #293171 by 0x2102
Now try to reducing those two settings:
sudo ethtool -C eth0 rx-usecs 0
sudo ethtool -C eth0 tx-usecs 0
If that errors out, try 1 or the lowest number the driver accepts.
13 Feb 2024 04:39 - 13 Feb 2024 04:43 #293192 by CORBETT
@0x2102
Hey man, thanks for posting that.  I haven’t had this problem before, but I like learning new info in case I ever do!!!  Nice…
@ zmrdko
Thanks for sharing your info.  I knew the “generic” component was slower as Dominik had stated so years ago, and I always try to avoid hardware that is not already in the driver…
Last edit: 13 Feb 2024 04:43 by CORBETT.
  • zmrdko
  • Elite Member
  • Elite Member
13 Feb 2024 22:54 #293274 by zmrdko
Hey @rodw
I think I stated it somewhere in the thread over ther, but I used this image:
rpi-5-debian-bookworm-6.1.61-rt15-arm64-ext4-2023-11-17-1520.img.xz
from linuxcnc.org/downloads/
  • zmrdko
  • Elite Member
  • Elite Member
13 Feb 2024 23:04 #293275 by zmrdko
@CORBETT
good point - I myself try to search here, which hardware work.
I bought some used hp prodesk, just to find out that it has realtek NIC, which has problems with latency.
Now I bought two dell optiplexes and they have intel NIC and much more settings available in BIOS regarding latency tuning.
But with new raspberry pi 5, someone has to find out first :)
Anyway, last comment from Bjarne says, that it is possible to port macb driver and suggested to compare some existing drivers (orig vs ethercat) to see what it takes.
However this is beyond my knowledge, so we have to find someone who is capable and willing to do it.
Or I can ask for quote at IGH.
14 Feb 2024 00:04 #293280 by rodw
The following user(s) said Thank You: zmrdko
  • zmrdko
  • Elite Member
  • Elite Member
14 Feb 2024 00:30 - 14 Feb 2024 00:31 #293283 by zmrdko
Thanks for suggestion.
I set bot values to 0.
Do you have any suggestion, how to verify, if its working?
I tried 250 000 ns thread and it did not make any difference (random first drive failing to get to OP)
Last edit: 14 Feb 2024 00:31 by zmrdko.
Time to create page: 0.114 seconds
