installing ethercat
- Abdulkareem
08 May 2024 12:27 #300114
by Abdulkareem
installing ethercat was created by Abdulkareem
hello guys
i am trying to install ethercat configurations for linuxcnc
i am using raspberry pi 4 with : 1 ) kernal : Linux raspberrypi 6.1.54-rt15 #1 SMP PREEMPT_RT Fri Nov 17 17:02:27 AEST 2023 aarch64 GNU/Linux
2) debian version : Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
3) linuxcnc version : Verbose mode on
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
i am using this link to install ethercat: gist.github.com/Bouni/8b4532d0bdf012bd83c65d3eb62f8aa2
i get error when i finish installing and run command "ethercat master" , the error is :
cnc@raspberrypi:~$ ethercat master
Failed to obtain number of masters: Failed to open master device /dev/EtherCAT0: No such file or directory
Release: 12
Codename: bookworm
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
- Thank you received: 4149
08 May 2024 19:54 #300155
Replied by rodw on topic installing ethercat
Obsolete instructions.
Please try this. It should work for the official pi image of 2.9.2
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The following user(s) said Thank You: Abdulkareem
- Abdulkareem
09 May 2024 09:47 #300208
by Abdulkareem
Replied by Abdulkareem on topic installing ethercat
i tried following the steps i keep getting this error
cnc@raspberrypi:~$ sudo apt update
E: Conflicting values set for option Signed-By regarding source download.opensuse.org/repositories/science:/EtherLab/Debian_12/ ./: /usr/share/keyrings/etherlab.gpg != /etc/apt/trusted.gpg.d/science_EtherLab.gpg
E: The list of sources could not be read.
cnc@raspberrypi:~$ sudo rm /usr/share/keyrings/etherlab.gpg
rm: cannot remove '/usr/share/keyrings/etherlab.gpg': No such file or directory
cnc@raspberrypi:~$ sudo rm /etc/apt/trusted.gpg.d/science_EtherLab.gpg
rm: cannot remove '/etc/apt/trusted.gpg.d/science_EtherLab.gpg': No such file or directory
cnc@raspberrypi:~$ sudo apt install linuxcnc-ethercat
- onceloved
- Thank you received: 59
09 May 2024 09:50 #300209
by onceloved
Replied by onceloved on topic installing ethercat
The following user(s) said Thank You: rodw, Abdulkareem
09 May 2024 10:39 - 09 May 2024 10:40 #300214
Good point. the source method and the repository files are stored in different locations so it probably gets confused
It is recommended to reinstall
Last edit: 09 May 2024 10:40 by rodw.
- Abdulkareem
09 May 2024 10:58 - 09 May 2024 11:00 #300215
by Abdulkareem
which kernel should i install, and if there are steps to follow it would be appreciated
Last edit: 09 May 2024 11:00 by Abdulkareem.
- Abdulkareem
09 May 2024 11:43 #300217
by Abdulkareem
thanks i fixed the error where do i get the linuxcnc-ethercat repository because i cannot locate the package
09 May 2024 21:49 #300245
If you use the official image from the downloads page, the ethercat packages should be dependencies of the linuxcnc-ethercat driver and would normally get installed automatically (but I don't use a pi so I can't check this, it may not work on your platform). Certainly ethercat should install ok
Otherwise follow these instructions.
github.com/linuxcnc-ethercat/linuxcnc-ethercat
Time to create page: 0.094 seconds
