Ethercat Salve
09 May 2024 16:48 #300227 by Abdulkareem
Ethercat Salve was created by Abdulkareem
when i type ethercat slaves, nothing shows, and it cannot recognize the slave when i type ethercat master. any help is appreciated
(venv) abdulkareem@debian:~$ ethercat master
Master0
  Phase: Idle
  Active: no
  Slaves: 0
  Ethernet devices:
    Main: 94:e7:0b:28:c9:1d (attached)
      Link: UP
      Tx frames:   4528
      Tx bytes:    271680
      Rx frames:   0
      Rx bytes:    0
      Tx errors:   0
      Tx frame rate [1/s]:    124    116     56
      Tx rate [KByte/s]:      7.3    6.8    3.3
      Rx frame rate [1/s]:      0      0      0
      Rx rate [KByte/s]:      0.0    0.0    0.0
    Common:
      Tx frames:   4528
      Tx bytes:    271680
      Rx frames:   0
      Rx bytes:    0
      Lost frames: 4528
      Loss rate [1/s]:        124    116     56
      Frame loss [%]:       100.0  100.0  100.0
  Distributed clocks:
    Reference clock:   None
    DC reference time: 0
    Application time:  0
                       2000-01-01 00:00:00.000000000
  • Moderator
  • Moderator
09 May 2024 16:57 #300228 by tommylight
Replied by tommylight on topic Ethercat Salve
Moved to "EtherCAT" section.
09 May 2024 21:57 #300247 by rodw
Replied by rodw on topic Ethercat Salve
Do you have ethercat slaves installed? eg connected via the ethercat network cable?
If not plesae review the instructions in the sticky carefully.
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Is /etc/ethercat.conf
correctly set up with your mac address.
What does dmesg say?
The following user(s) said Thank You: Abdulkareem
12 May 2024 09:10 #300427 by Abdulkareem
Replied by Abdulkareem on topic Ethercat Salve
Thank you, problem solved. KERNEL=="EtherCAT[0-9]", MODE="0777" was masking the mac address
Time to create page: 0.103 seconds
