joint 0 follwing error and driver Er 818
- Abdulkareem
13 May 2024 11:21 #300504
by Abdulkareem
joint 0 follwing error and driver Er 818 was created by Abdulkareem
Hello everyone, i am trying to jog x-axis through ethercat, but the driver gives er 818, and linuxcnc gives a message of joint 0 following error. i am using leadshine EL8 Ec400f servo driver. here are the ini,hal, and xml files. Any help is highly appreciated.
- jjdege
- Thank you received: 38
13 May 2024 12:24 - 13 May 2024 12:28 #300511
by jjdege
Replied by jjdege on topic joint 0 follwing error and driver Er 818
try to give the right sequence to IDX in the .xml file
it should be, I think
slave idx="2" type="generic" vid="00004321" pid="000010c2" configPdos="true" name="EL8"slave idx="0" type="generic" vid="00004321" pid="000010c2" configPdos="true" name="EL8"
Last edit: 13 May 2024 12:28 by jjdege.
The following user(s) said Thank You: Abdulkareem
Time to create page: 0.090 seconds
