EtherCAT options for spindle encoder
- jimwhiting
- Thank you received: 6
13 Jun 2024 20:05 #302968
by jimwhiting
EtherCAT options for spindle encoder was created by jimwhiting
I'm having trouble navigating the options for spindle position feedback for a lathe conversion. My existing system uses an encoder connected to a Mesa 7i76.
What are my options? EK1100 + EL5151?
What other solutions have people come up with?
Regards,
Jim.
Regards,
Jim.
- GuiHue
- Thank you received: 39
14 Jun 2024 08:59 #302992
by GuiHue
Replied by GuiHue on topic EtherCAT options for spindle encoder
That is a sensible approach. Some drives have their own inputs for encoders and can pass through that signal via ethercat. May be an option, if the existing drive supports this.
- pippin88
- Thank you received: 51
14 Jun 2024 12:23 #303004
by pippin88
Replied by pippin88 on topic EtherCAT options for spindle encoder
Leadshine now have a similar system of ethercat base unit + multiple modules
R2EC I think it's called
Much cheaper.
There is some discussion about it github.com/linuxcnc-ethercat/linuxcnc-ethercat/issues/434
Much cheaper.
- jimwhiting
19 Jun 2024 19:09 #303378
by jimwhiting
Replied by jimwhiting on topic EtherCAT options for spindle encoder
Thanks, I've had a look at the Leadshine offerings, they don't appear to be available anywhere.
Ultimately I did want a servo to drive the spindle, but I couldn't find one that matched my specifications. (single phase 220v supply, ~3kW, Ethercat, 4krpm+)
I did find the following:
www.oksa.co.uk/product/ecat-2074a-etherc...lute-encoder-master/
Which is a 4 channel BISS/SSI encoder interface for around £545. Which makes it cheaper than the beckhoff interface and encoder module. 10MHz capable counters.
Or a 3 channel ABZ input for around £273. (much cheaper than beckhoff) - but it can only count at 4MHz
www.oksa.co.uk/product/ecat-2093-etherca...tal-encoder-counter/
- pippin88
20 Jun 2024 07:34 #303402
by pippin88
Did you try Leadshine directly? Or ask where the person on github got theirs?
I think R2EC are new so may not have made it to retail channels like Aliexpress yet
- jimwhiting
20 Jun 2024 08:25 #303403
by jimwhiting
I've put a question in with the UK distributor for Leadshine to see if they have any info.
Time to create page: 0.190 seconds
