Help Needed: Cracking the Code on LinuxCNC Servo Homing Setup!
2 years 4 months ago #303424 by Aciera
sets joint.0.custom-homing-is-requested true
You are using the wrong hal command (sets) here as that is for setting a signal.
Use 'setp' instead:
setp joint.0.custom-homing-is-requested true
2 years 4 months ago #303425 by eduard
Ok, I changed to setp, but the pin is not writebale.
M5_EtherCAT.hal:33: pin 'joint.0.custom-homing-is-requested' is not writable
2 years 4 months ago - 2 years 4 months ago #303426 by Aciera
[edit]
We are trying to set the wrong pin
I'm sorry the line should be:
setp joint.0.request-custom-homing true
Last edit: 2 years 4 months ago by Aciera. Reason: fix wrong command
2 years 4 months ago #303427 by eduard
Yepp, I did not see either.
But here is the next error:
HAL: ERROR: signal 'x-home-request' already has output pin
2 years 4 months ago #303428 by Aciera
Besides this line:
net x-home-request joint.0.custom-homing-is-requested => cia402.0.home
do you have another line with 'x-home-request' in your hal?
2 years 4 months ago #303429 by Aciera
Ok, it seems that 'cia402.0.home' is of type 'IO' not 'IN' so I changed the custom homing comp to make 'joint.0.custom-homing-is-requested' have type 'IO'. Not sure if this works but give it a go:
File Name: el8_homeco...06-20.gz
File Size:4.47 KB
Don't forget to halcompile --install the new comp.
Time to create page: 0.410 seconds
