- Thank you received: 103
I think you are misinterpreting the term 'custom homing driver'. The reason custom homing modules were brought in is the simple fact that before the 'standard' procedure, that comes with an installation, had to handle all the possible homing scenarios which means that with every new addition the source code got more complicated. The custom homing module makes it possible to create homing procedures built for specific purposes without having to retain all the built in functionality. But if you want you can even use that custom module only for specific joints while choosing from the built in homing procedures for the others.Instead of a custom homing driver, a standard driver with deterministic behavior as I described should be used that way everyone involved speaks a common language.
