Please HELP config ethercat servo motor
- abdulasis12
- Thank you received: 8
25 Jun 2024 15:35 #303756
by abdulasis12
Please HELP config ethercat servo motor was created by abdulasis12
Hi
I try to use EtherCAT servo motor first time.
I read in forum.linuxcnc.org/ethercat/45336-etherc...-step-by-step#237098
I config step by step done
I clone config from github.com/rodw-au/linuxcnc-cia402/tree/main
I Download .XML my servo put in folder and in .hall i add
loadusr -W lcec_conf HCFA_X3E30.xml
I run LCNC show massege error:
./cia402.hal:15: lcec_conf exited without becoming ready
6836
how to fix this error ?
6836
- Thank you received: 4150
25 Jun 2024 19:28 #303777
Replied by rodw on topic Please HELP config ethercat servo motor
The XML file you are using is for Twincat on Windows
It is useless for Linuxcnc.
Please review the example XML files in the config you cloned.
You need to write something similar for your drive and other slaves you are using.
The following user(s) said Thank You: abdulasis12
- onceloved
- Thank you received: 59
26 Jun 2024 01:38 #303803
by onceloved
Replied by onceloved on topic Please HELP config ethercat servo motor
Are you Chinese? If yes, I can help you with remote configuration.
- abdulasis12
26 Jun 2024 09:46 #303818
by abdulasis12
Replied by abdulasis12 on topic Please HELP config ethercat servo motor
YES, china i have any desk
- abdulasis12
26 Jun 2024 09:57 #303819
by abdulasis12
I will read more about etherCAT and try again
thank you.
Thank you for reply MR.rodwThe XML file you are using is for Twincat on Windows
thank you.
- abdulasis12
26 Jun 2024 15:09 - 26 Jun 2024 20:59 #303833
by abdulasis12
I try re download file from github.com/rodw-au/linuxcnc-cia402/tree/main
and first time show error shutdown.hal i go to # all line
run linuxcnc from cmd
show this massege :
this my ethercat network
some can guild me ?
Thank you.
Asis
show this massege :
linuxcnc@debian:~/linuxcnc/configs/linuxcnc-cia402-main$ linuxcnc
LINUXCNC - 2.9.2
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/linuxcnc-cia402-main'
Machine configuration file is 'cia402.ini'
Starting LinuxCNC...
emc/iotask/ioControl_v2.cc 888: iov2: can't load tool table.
Note: Using POSIX realtime
Found file(REL): ./cia402.hal
Failed to execute SDO download: Input/output error
LCEC: slave 0.0: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2000:00
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2007:06
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x05, size 1, byte0=5, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2007:05
LCEC: slave 0.0: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2011:00
LCEC: slave 0.0: Failed to execute SDO download (0x6098:0x00, size 2, byte0=17, error -5, abort_code 06070010)
LCEC: failed to configure slave 0.0 sdo 6098:00
LCEC: slave 0.0: Failed to execute SDO download (0x607c:0x00, size 2, byte0=0, error -5, abort_code 06070010)
LCEC: failed to configure slave 0.0 sdo 607c:00
LCEC: slave 0.0: Failed to execute SDO download (0x609a:0x00, size 2, byte0=244, error -5, abort_code 06070010)
LCEC: failed to configure slave 0.0 sdo 609a:00
LCEC: slave 0.0: Failed to execute SDO download (0x6099:0x01, size 2, byte0=196, error -5, abort_code 06070010)
LCEC: failed to configure slave 0.0 sdo 6099:01
LCEC: slave 0.0: Failed to execute SDO download (0x6099:0x02, size 2, byte0=244, error -5, abort_code 06070010)
LCEC: failed to configure slave 0.0 sdo 6099:02
LCEC: slave 0.1: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.1 sdo 2000:00
LCEC: slave 0.1: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.1 sdo 2007:06
LCEC: slave 0.1: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.1 sdo 2011:00
Failed to execute SDO download: Invalid argument
LCEC: slave 0.2: Failed to execute SDO download (0x2000:0x00, size 2, byte0=88, error -22, abort_code 08e49a08)
LCEC: failed to configure slave 0.2 sdo 2000:00
LCEC: slave 0.2: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code 08e49a08)
LCEC: failed to configure slave 0.2 sdo 2007:06
LCEC: slave 0.2: Failed to execute SDO download (0x2011:0x00, size 2, byte0=0, error -22, abort_code 08e49a08)
LCEC: failed to configure slave 0.2 sdo 2011:00
Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO entry registration failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./cia402.hal:15: waitpid failed /usr/bin/rtapi_app lcec
./cia402.hal:15: /usr/bin/rtapi_app exited without becoming ready
./cia402.hal:15: insmod for lcec failed, returned -1
Running HAL shutdown script
iov2: exiting
LinuxCNC terminated with an error. You can find more information in the log:
/home/linuxcnc/linuxcnc_debug.txt
and
/home/linuxcnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminalthis my ethercat network
linuxcnc@debian:~/linuxcnc/configs/linuxcnc-cia402-main$ ethercat slaves
0 0:0 PREOP + BK1120 EtherCAT Buskoppler
1 1:0 PREOP + HCFA X3E Servo Driver
linuxcnc@debian:~/linuxcnc/configs/linuxcnc-cia402-main$ Thank you.
Asis
Last edit: 26 Jun 2024 20:59 by abdulasis12.
- abdulasis12
26 Jun 2024 20:48 - 26 Jun 2024 20:51 #303849
by abdulasis12
linuxcnc@debian:~/linuxcnc/configs/linuxcnc-cia402-main$ halcmd loadusr -W lcec_conf ethercat-conf.xml
linuxcnc@debian:~/linuxcnc/configs/linuxcnc-cia402-main$ halcmd show pin lcec
Component Pins:
Owner Type Dir Value Name
4 u32 OUT 0x00000001 lcec.conf.master-count
4 u32 OUT 0x00000004 lcec.conf.slave-count
Last edit: 26 Jun 2024 20:51 by abdulasis12.
- onceloved
27 Jun 2024 01:17 #303863
by onceloved
加我QQ或微信304394405
- abdulasis12
27 Jun 2024 02:31 #303866
by abdulasis12
LINUXCNC - 2.9.2
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/linuxcnc-cia402-main/.'
lcec_conf: ERROR: Parse error at line 4: not well-formed (invalid token)
./cia402.hal:9: waitpid failed lcec_conf lcec_conf
./cia402.hal:9: lcec_conf exited without becoming ready
iov2: exiting
and
iov2: exiting
and
