Running EtherCat on none supported EtherCat servo drivers using PWM
29 Jun 2024 19:25 #304052 by akim14
I need help answering some EtherCat questions; I plan on using Beckhoff ek1100. However, the servo drivers I have support PWM only and not EtherCAT. Is there a slave device I can use to help generate the PWM needed to run the drives? Or what options do I can.
29 Jun 2024 21:19 #304060 by ihavenofish
beckhoff has some servo control modules, but they literally cost more than buying a delta b3 full kit. So probably not worth while.
30 Jun 2024 01:04 #304070 by rodw
There are stand alone modules made by people other than  Beckhoff.
one is the Rtelligent RTEC1616 which has 4 PWM outputs
02 Jul 2024 03:40 #304195 by akim14
Thank you. I will look into the driver's cost
02 Jul 2024 03:41 #304196 by akim14
Wow this may be what I just need, Thank you so much for that information
Time to create page: 0.278 seconds
