- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Failed to open /dev/EtherCAT0: Permission denied
- bkt
- Thank you received: 114
14 Jul 2024 12:52 #305140
by bkt
Failed to open /dev/EtherCAT0: Permission denied was created by bkt
in new mini pc installation mint21 Lcnc 2.9.2 try to launch a copy of my old config ..... I obtain these error :
But file owner is root and GRUP is mine .... so can launch in terminal freely command "ethercat slaves" with reply whitout using sudo .... why these? First time see these error ...
regeards for any suggest
- bkt
14 Jul 2024 12:58 #305145
by bkt
Replied by bkt on topic Failed to open /dev/EtherCAT0: Permission denied
exactly obtain these if lauch from terminal ..
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./gc_sim_1ax_cl.hal
creating ladder-state
LCEC: requesting master 0 (index 0) failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./gc_sim_1ax_cl.hal:17: waitpid failed /usr/bin/rtapi_app lcec
./gc_sim_1ax_cl.hal:17: /usr/bin/rtapi_app exited without becoming ready
./gc_sim_1ax_cl.hal:17: insmod for lcec failed, returned -1
- Thank you received: 4149
14 Jul 2024 21:02 #305172
Replied by rodw on topic Failed to open /dev/EtherCAT0: Permission denied
Sound like you missed an installation step. Please refer to the sticky where it mentions udev rules.
The following user(s) said Thank You: bkt
- bkt
14 Jul 2024 22:20 #305177
by bkt
other problem with permission ... but not all ...in these config i have not joint or axis .... and when I've these situation until 2.9.0 I use one axis, for example X, witout set it on hal file and whitout move it. I set only on ini file. But because never use it ... no problem ... not in 2.9.2 I have a problem whit these situations ..... and obtain:
but not know how eliminate it ... is not set on xml where there is only digital In Out el1008 and el2008 .... not set in .hal file ... and present only in .ini file .... but never use it because use only classic ladder .... but seems 2.9.2 check if axis is well set ... so i have a problem .... there are a way to solve or need to use core_sim.hal file? ....
(classicladder:13667): dbind-WARNING **: 00:13:43.156: Couldn't connect to accessibility bus: Failed to connect to socket /root/.cache/at-spi/bus_0: Permission denied
task: machine: 'GC-SIM-CL' version 'unknown'
note: MAXV max: 1200.000 units/sec 72000.000 units/min
note: LJOG max: 1200.000 units/sec 72000.000 units/min
note: LJOG default: 1000.000 units/sec 60000.000 units/min
waiting for s.joints<0>, s.kinematics_type<0>
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
Waiting for component 'inihal' to become ready...........USRMOT: ERROR: command timeout
....................USRMOT: ERROR: command timeout
.....A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
.Shutting down and cleaning up LinuxCNC...
emcMotionInit: emcTrajInit failedbut not know how eliminate it ... is not set on xml where there is only digital In Out el1008 and el2008 .... not set in .hal file ... and present only in .ini file .... but never use it because use only classic ladder .... but seems 2.9.2 check if axis is well set ... so i have a problem .... there are a way to solve or need to use core_sim.hal file? ....
- bkt
14 Jul 2024 22:27 #305178
by bkt
these can be a problem?? ... seems classicladder is correctly show ... after i have problem above .... if add core_sim.hal in my .ini file hal sections .... joint0 problem disappear ... but rem,ain cassicladder warning and these messages ...
so if someone have some ideas ... it help a lot.
(classicladder:14034): dbind-WARNING **: 00:22:21.274: Couldn't connect to accessibility bus: Failed to connect to socket /root/.cache/at-spi/bus_0: Permission denied
Found file(REL): ./core_sim.hal
trivkins: already exists
./core_sim.hal:5: waitpid failed /usr/bin/rtapi_app trivkins
./core_sim.hal:5: /usr/bin/rtapi_app exited without becoming ready
./core_sim.hal:5: insmod for trivkins failed, returned -1
ERROR CLASSICLADDER- Error initializing classicladder user module.
- bkt
14 Jul 2024 22:29 #305179
by bkt
seems completely missing .... these new install was paused from 2 weeks ... so these is loose ... thanks a lot
udev rules.
- bkt
15 Jul 2024 05:07 - 15 Jul 2024 05:08 #305191
by bkt
about joint-0 problem I solve adding in my hal file these row for simulate X axis that not use ...
about warning is disappear adding these ... so seems nothing so important .... all works
loadrt ddt names=ddt_x,ddt_xv
# load additional blocks
loadrt hypot names=vel_xy
# add motion controller functions to servo thread
# link the differentiator functions into the code
addf ddt_x servo-thread
addf ddt_xv servo-thread
# create HAL signals for position commands from motion module
# loop position commands back to motion module feedback
net Xpos joint.0.motor-pos-cmd => joint.0.motor-pos-fb ddt_x.in
# send the position commands thru differentiators to
# generate velocity and accel signals
net Xvel ddt_x.out => ddt_xv.in vel_xy.in0
net Xacc <= ddt_xv.outabout warning is disappear adding these ... so seems nothing so important .... all works
Last edit: 15 Jul 2024 05:08 by bkt.
- scottlaird
- Thank you received: 161
15 Jul 2024 23:19 #305292
by scottlaird
Replied by scottlaird on topic Failed to open /dev/EtherCAT0: Permission denied
We should really modify the EtherCAT package to install these automatically, as it's a common problem. Presumably we'd want to create an `ethercat` group and use it in udev instead of giving EtherCAT access to everyone.
The following user(s) said Thank You: endian
- scottlaird
15 Jul 2024 23:27 #305293
by scottlaird
I'm not actually sure who owns the EtherCAT package, but I sent email to Bjarne about it, hopefully he can help get it to the right people.
The following user(s) said Thank You: rodw, endian
- scottlaird
16 Jul 2024 14:50 #305362
by scottlaird
...and Bjarne says that it's been added. Hopefully this won't be a problem in the future.
The following user(s) said Thank You: tommylight, bkt, rodw, Aciera, endian
- EtherCAT
Time to create page: 0.275 seconds
