Hi Endian,sorry, but I still cannot get it working. I spent many hours on it yesterday evening, and I am obviously still doing something wrong.I am not sure whether I am missing an important step, whether I made a mistake in the configuration, or whether I am still missing a required driver or component.As you suggested, I redid the whole process from scratch using the current translator from the publish folder: fresh TwinCAT export, start the
, use
, and then convert the export again. This time the conversion itself seems to have worked properly.I am attaching:
- the fresh
generated by the current translator
- my adapted machine
with the other real bus slaves added back in
Current status on the real machine:
LinuxCNC 2.9.8
IgH EtherCAT master 1.6.8
all non-AX slaves go OP
only the AX5125-0000-0216 stays in
Current error:
AX5125 stays in PREOP + ERROR.
AL status message 0x0045: "MBX_SOE"
currently shows:ethercat slaves
0 0:0 OP + EK1100 EtherCAT Coupler (2A E-Bus)
1 0:1 OP + EL1008 8K. Dig. Eingang 24V, 3ms
2 0:2 OP + EL1008 8K. Dig. Eingang 24V, 3ms
3 0:3 OP + EL1008 8K. Dig. Eingang 24V, 3ms
4 0:4 OP + EL2008 8K. Dig. Ausgang 24V, 0.5A
5 0:5 OP + EL2008 8K. Dig. Ausgang 24V, 0.5A
6 0:6 OP + EL2008 8K. Dig. Ausgang 24V, 0.5A
7 0:7 PREOP E AX5125-0000-0216 EtherCAT Drive (SoE, 1 Ch.)
8 0:8 OP + EK1100 EtherCAT Coupler (2A E-Bus)
9 0:9 OP + EL2008 8K. Dig. Ausgang 24V, 0.5A
10 0:10 OP + EK1100 EtherCAT-Koppler (2A E-Bus)
11 0:11 OP + EL1008 8K. Dig. Eingang 24V, 3ms
12 0:12 OP + EL3255 5K. Potentiometerauswertung mit SensorversorgungCould you please compare:
- the freshly generated translator XML
- the adapted machine bus XML
My main question is:
Do you already see from these two XML files what is still wrong in the AX5125 startup / SoE configuration, or what the minimal correct AX5125
configuration should look like?If there is already a known working example config for an AX5125 with
, that would also help a lot, because at this point I am worried that I may still be missing something fundamental.ChatGPT helped me sort the files and compare the configs, but the machine is still not getting past
, so I would really appreciate your expert view on the actual AX5125 setup.Thanks a lot for your time.
greetings
Tom
