linuxcnc 2.9.2 ethercat problem
02 Aug 2024 16:46 - 06 Aug 2024 18:12 #306762 by Moutomation
linuxcnc 2.9.2 ethercat problem was created by Moutomation
Linuxcnc is best cnc
Last edit: 06 Aug 2024 18:12 by Moutomation.
02 Aug 2024 17:54 - 06 Aug 2024 18:13 #306768 by Moutomation
Replied by Moutomation on topic linuxcnc 2.9.2 ethercat problem
rodw is very helpful to everyone regarding ethercat.
Last edit: 06 Aug 2024 18:13 by Moutomation.
02 Aug 2024 17:57 #306770 by scottlaird
Replied by scottlaird on topic linuxcnc 2.9.2 ethercat problem
IIRC, the Ethercat people just did a major version upgrade after literally years of leading up to it. We should probably either pin LCEC to v 1.5.x or see what it takes to fix whatever upgrade problems are happening. I'll take a look at it later today if possible.
The larger issues are kind of complex, and discussing them would get in the way of fixing the short-term bug. I'll just say that if you really want to depend on something in a production environment, then you either want to be paying someone for dependable support, have the ability to fix just about anything yourself, or be able to live without it for a while. This isn't LinuxCNC-specific, or really specific to any technology at all.
I don't know of anyone offering this level of support for LinuxCNC today, but I've never really looked.
The following user(s) said Thank You: PCW, Aciera, Moutomation
02 Aug 2024 18:08 - 06 Aug 2024 18:13 #306772 by Moutomation
02 Aug 2024 18:11 #306773 by Aciera
Replied by Aciera on topic linuxcnc 2.9.2 ethercat problem
I installed it on another computer a few weeks ago and there was no problem.
I think Linuxcnc's ethercat support can be turned off by someone who provides this support whenever they want.
I think Linuxcnc is not suitable for professional use because an installation that could be done last week cannot be done this week.
For example, let's imagine a person who is building a machine with Linux, everything is finished and it is at the operating stage. There is an ethercat problem right now and it can't be solved. How can it wait for it to be fixed? It can't wait, that's why it doesn't use Linuxcnc, it uses professional devices. Yes, Linuxcnc may be free, but it doesn't matter if it is free if it doesn't work when it should.
Well look at what happened to all those pros using Windows a couple of weeks ago.
I'm sorry but this kind of consumer attitude is not helpful, if you need 100% reliability and availability then you may want to consider investing the 20 or 30 grand in a professional solution.
You may not be aware of this but pretty much everything here is the result of donated time. Made available to the public to enable people like you build things they could not otherwise dream of making, this forum included. Where is your contribution to warrant such a fit?
The following user(s) said Thank You: PCW, endian
02 Aug 2024 18:33 #306776 by Aciera
I buy and use professional devices, I pay money for these devices. I only shared this to prevent anyone from getting hurt. Because I can't do something I did a week ago a week later. For example, who can guess that something that worked a week ago won't work a week later. And since I worked it before, I could start a new job thinking it would work again and I could be disappointed. My aim is to prevent others from falling into these situations. .
People like you just make me sad I'm just glad there are not too many like you around here.
The following user(s) said Thank You: onceloved
02 Aug 2024 18:34 #306777 by Moutomation
I think you are far from professional CNCs. Devices with inputs and outputs that can control 256 axes are 1000 euros. Also, a person who needs help is a novice in these matters, how can he contribute? Did you start this job by helping directly? Did you not need help at all in the beginning? I have been working on it for a month, I opened a few issues in just a few days, and I only got a half-answer on 1 issue.
02 Aug 2024 18:46 #306778 by Moutomation
Why are you so upset with what I said? Do you like it when people beg for help? Or do you like it when they are drowning in a lot of problems? I am just informing people about these things.
02 Aug 2024 18:49 #306779 by Aciera
Exactly and you also get free support 24/7. Then why don't you use those?
I was actually the one that gave you that 'half-answer' and I just gave you another one in the other thread.
And let me give you a bit more free advice here:
If you get something for free and need help from people who also help you for free then the least those people deserve is some respect.
The following user(s) said Thank You: PCW, Clive S, endian
02 Aug 2024 18:56 #306781 by Moutomation
You helped me a lot by replying. You are telling me to change the source code,If I had the knowledge to change the source code, I would not ask this question.
Time to create page: 0.189 seconds
