linuxcnc 2.9.2 ethercat problem
- onceloved
- Thank you received: 59
03 Aug 2024 06:24 #306830
by onceloved
Replied by onceloved on topic linuxcnc 2.9.2 ethercat problem
我刚在虚拟机中全新安装了linuxcnc和ethercat 没有任何问题
1,2,3我比较熟 有需要我可以帮你 4,5,7,没弄过
至于由windows控制linuxcnc 在中国这边可以使用向日葵远程控制来控制linuxcnc 我一直这么做 包括加工https://sunlogin.oray.com/
- Thank you received: 4149
03 Aug 2024 11:40 #306838
For the record, I had my part fixed in 24 hours but held back announcing the update because Ethercat didn't install. Once they fixed their bug, there was no further action required by me.
Replied by rodw on topic linuxcnc 2.9.2 ethercat problem
This isn't possible. Due to licencing requirements, Linuxcnc is unable to keep a copy of Ethercat because we are not a company. So linking to an external repository is the best we can do.If it weren't for you it wouldn't have been solved so quickly. Updating Ethercat may not be under Linuxcnc's control, but I think that such important files, versions and packages that were running in the past should be preserved or backed up. I appreciate your support and you serve the purpose of the Forum's existence.
The following user(s) said Thank You: Moutomation
- Moutomation
- Thank you received: 11
04 Aug 2024 18:48 #306937
by Moutomation
Replied by Moutomation on topic linuxcnc 2.9.2 ethercat problem
I think I was wrong in my first message, I apologize to everyone for that. I think the admins should delete this thread.
- Moutomation
04 Aug 2024 18:53 #306938
by Moutomation
I also apologize to Aciera and Tommylight, I shouldn't have argued with you.
The following user(s) said Thank You: tommylight, Clive S, Aciera
- Thank you received: 2176
05 Aug 2024 06:00 #306967
Replied by Aciera on topic linuxcnc 2.9.2 ethercat problem
I agree.I think the admins should delete this thread.
- Thank you received: 7480
05 Aug 2024 10:29 #306986
Replied by tommylight on topic linuxcnc 2.9.2 ethercat problem
Anyone against deleting this topic?
- Moutomation
05 Aug 2024 16:39 #307012
by Moutomation
I think it should definitely be deleted.
Time to create page: 0.116 seconds
