kernel for ethercat
- papagno-source
- Thank you received: 13
06 Aug 2024 18:47 #307115
by papagno-source
kernel for ethercat was created by papagno-source
Good morning everyone. I am using debian 10 and kernel 4.19.19-rt-amd 64. I noticed that in the repositories there are later versions and I installed the kernel 4.19.27-rt-amd64 which still works well with ethercat. I also noticed that there are kernels 5.10.0-0.deb10.30-rt-amd64. This kernel would work with ethercat. Regarding performance and stability which kernel is better to use?
- Thank you received: 4149
06 Aug 2024 23:27 #307130
Replied by rodw on topic kernel for ethercat
Most people are running Debian 12 and Linuxcnc 2.9.3 becasue the ISO on the downloads page also allows ethercat to be installed from repositories as per the sticky in this section.
- papagno-source
07 Aug 2024 15:54 #307186
by papagno-source
Replied by papagno-source on topic kernel for ethercat
Yes I understand, but I already have some machines with Debian 10 and I have no problems. Wanting to continue with Debian 10, which is the most stable Kernel of the 4.x series.
Is it possible to use the 5.x kernel?
Time to create page: 0.223 seconds
