Rexroth Indradrive CS and KEB G6
- kworm
- Thank you received: 16
16 Aug 2024 03:29 #307876
by kworm
Rexroth Indradrive CS and KEB G6 was created by kworm
Hi, I'm looking at attempting to convert a large router to LinuxCNC from the vendors proprietary control. It's using Ethercat with Beckoff EK1100, Bosch/Rexroth Indradrive CS servo drives, and a KEB G6 VFD for the spindle. I have some experience with LinuxCNC but not Ethercat and from the searching I've done it appears that the Beckoff gear is likely supported very well and I've seen some mention of the Indradrive CS from back in 2013 but nothing on the KEB. I did see some mention of Ethercat VFDs and supporting vl mode being under development, etc. Just thought I would see if anyone had experience with any of these and what I might run into in doing the conversion.
Thanks,
Kevin
Thanks,
Kevin
03 Sep 2024 12:31 #309278
Replied by andypugh on topic Rexroth Indradrive CS and KEB G6
VFDs generally support numerous control modes, so even if you can't directly control it by EtherCAT you may be able to use Modbus, or even analogue voltage from an EtherCAT module.
Time to create page: 0.083 seconds
