is there some basic list to build the net ?
- AndyDM01
20 Aug 2024 18:05 #308235
by AndyDM01
is there some basic list to build the net ? was created by AndyDM01
I would be very happy if someone could point me to a list of standard net to build stuff from ...
like : net x-home or net x-limit or net torch-on .... stuff like this
OR I don't have to care and i can just create whatever i want?
I want to use most of the IO on my card that has 16 inputs and 16 outputs ...
before i had a usb-bob for mach3 and had 4 inputs and 4 outputs
- zmrdko
- Thank you received: 49
21 Aug 2024 07:10 #308265
by zmrdko
Replied by zmrdko on topic is there some basic list to build the net ?
I would suggest starting from basics like homing/limit switches. Maybe try some E-stop for safety. And as you will use the machine, you will find out what do you need. You can also get some inspiration from control panels on industrial machines
The following user(s) said Thank You: AndyDM01
- AndyDM01
21 Aug 2024 15:56 #308308
by AndyDM01
Replied by AndyDM01 on topic is there some basic list to build the net ?
did read almost half of the linuxcnc documentation and i didn't see anything that would answer my question ... are there basic rules / commands to start from in linuxcnc-ethercat....
I have been tru all this shite 20+years ago when i tried to get a twincat controlled plc to work... doesn't look like the information base to get stuff working has improved... digging thru the twincat2 information was a pain in the ass... trying to find answers in this forum ... vage information
- AndyDM01
21 Aug 2024 15:58 #308309
by AndyDM01
it's you in the F16? small cockpit so im not sure F18 or F16 ...
- AndyDM01
21 Aug 2024 16:00 #308310
by AndyDM01
SU 27?
- Thank you received: 426
21 Aug 2024 23:19 #308348
Replied by Cant do this anymore bye all on topic is there some basic list to build the net ?
"did read almost half of the linuxcnc documentation"
That's the issue.
It's there you just need to look.
That's the issue.
- Thank you received: 4149
21 Aug 2024 23:42 #308350
Linuxcnc does not care and you can use whatever you want.
Over time you will build your own style that works for you.
With ethercat, I like to put the drives at the top of the list so they get numbered the same as th ejoints but you can set a name j0.j1 etc.
Replied by rodw on topic is there some basic list to build the net ?
I think that is the biggest difference between Linuxcnc and Mach3, Here, you start with a blank canvas, Mach has some structure about its setup.I would be very happy if someone could point me to a list of standard net to build stuff from ...
- zmrdko
22 Aug 2024 14:29 - 22 Aug 2024 14:29 #308400
by zmrdko
also you can get some inspiration in my config: github.com/zmrdko/3dworks_ethercat_lcec
not finished, but basics work.
Last edit: 22 Aug 2024 14:29 by zmrdko.
- AndyDM01
23 Aug 2024 14:11 #308465
by AndyDM01
wow
you just gave me a big push forward
thank you very much
thank you very much
Time to create page: 0.468 seconds
