- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- stuff you might want to know when you start with ethercat drivers
- AndyDM01
18 Sep 2024 16:04 #310375
by AndyDM01
stuff you might want to know when you start with ethercat drivers was created by AndyDM01
So I am starting this topic because I am 300% sure I fucked up somewhere in the start of the installation of linuxcnc ethercat from repositories....
first advice would be to check this topic untill the last grain of information because there might be something there that will save you a lot of time trying to figure out why your project doesn't work....
first tip i can give after that one would be ....
Ethercat only works when everything is neatly organized and everything is spelled correctly and all stuff is called the same
Ethercat also likes perfect order in stuff, you can not to make disorder in the way ethercat READS stuff and WRITES stuff...
look at the examples how in the XML folder the read/write is written in the start of the XML
- AndyDM01
18 Sep 2024 16:05 #310376
by AndyDM01
Replied by AndyDM01 on topic stuff you might want to know when you start with ethercat drivers
please feel free to add more information after this
- EtherCAT
Time to create page: 0.094 seconds
