problem with cia402
13 Oct 2024 10:45 #311946 by Abdulkareem
problem with cia402 was created by Abdulkareem
hello i get the following error when i run my ethercat configuration :
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/precisonteq/linuxcnc/configs/KINS_2TILTS_COMPLETE_A_CASES/KINS'
Machine configuration file is 'cia402.ini'
INIFILE=/home/precisonteq/linuxcnc/configs/KINS_2TILTS_COMPLETE_A_CASES/KINS/cia402.ini
VERSION=1.1
check_config: Unchecked: [KINS]KINEMATICS=xyzab_tdr_kins
PARAMETER_FILE=xyzab-tdr.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z A B
Starting LinuxCNC...
Found file(REL): ./cia402.hal
*** xyzab_tdr_kins.comp setup ok
Debug file information:
Note: Using POSIX realtime
cia402: dlopen: /usr/lib/linuxcnc/modules/cia402.so: cannot open shared object file: No such file or directory
./cia402.hal:8: waitpid failed /usr/bin/rtapi_app cia402
./cia402.hal:8: /usr/bin/rtapi_app exited without becoming ready
./cia402.hal:8: insmod for cia402 failed, returned -1
46056
Stopping realtime threads
Unloading hal components
  • Moderator
  • Moderator
13 Oct 2024 12:09 #311956 by tommylight
Replied by tommylight on topic problem with cia402
There is no cia402 module installed, see how to install it, or if it should be installed with EtherCAT.
The following user(s) said Thank You: Abdulkareem
Time to create page: 0.127 seconds
