Performance issues after switching from LCNC 2.8.4 Buster to 2.9.3 Bookworm
2 years 2 weeks ago - 2 years 2 weeks ago #312229 by BaxEDM
Just switched from LCNC 2.8.4 Buster to 2.9.3 Bookworm and am running into what seems to be a performance issue. Occasionally I get a random servo following error, which is impossible since I run my steppers open loop. I use EtherCAT stepper drives. These errors stop G-code execution at random moments and turn the machine off, making it unusable.
I remember when I first tried out LCNC on a really old laptop I got this as well, I then switched to a dedicated mini PC and never saw those errors again, until now. Now I'm running the same stuff on the same PC, but instead with LCNC 2.9.3 and Bookworm, the occasional servo errors have returned.
The mini-PC is a 8GB memory, 4-core Intel celeron 2-2.7GHz (The Minisforum GK41).
My initial thought was to replace the PC with something faster, but that might not be the right approach since the hardware is probably already fast enough. It works like a charm on 2.8.4 + Buster. Could it be that Bookworm is so much more demanding? I would like to hear what the experts on the forum recommend.
Last edit: 2 years 2 weeks ago by BaxEDM.
2 years 2 weeks ago #312247 by Aciera
(Maybe an admin could move this to the EtherCAT section)
2 years 2 weeks ago #312257 by Todd Zuercher
Have you checked to see if your new installation is having latency issues? Just because your PC had acceptable latency with Buster, does not mean that it will with Bookworm (at least not necessarily right out of the box). You may have to tweak some kernel parameters to improve the latency to acceptable levels.
I'm not completely familiar with how Linuxcnc EtherCAT configurations work or should be set up. But at a minimum there must be some form of feedback loop for Linuxcnc. Usually for open loop systems the stepgen sends a position feedback signal back to Linuxcnc. If that feedback signal is from an external hardware stepgen, you can get a large enough following error to set an alarm if latency causes delayed reads of the feedback, especially if following error limits are set too tight.
Did you reuse the old working machine configuration you created in Buster, or did you start over making a new config? (If you started fresh, is it possible you didn't configure something the same?)
You might need to post copies of your configuration files to get better answers.
2 years 2 weeks ago #312262 by tommylight
Done.
Thank you.
2 years 2 weeks ago - 2 years 2 weeks ago #312356 by BaxEDM
I checked out the latencies:
On LCNC 2.8.4 + Buster:
Servo thread (1ms): Max interval 1024713 ns, Max Jitter 25556 ns
Base thread (25us): Max interval 65792 ns, Max Jitter 40792 ns
On LCNC 2.9.3 + Bookworm
Servo thread (1ms): Max interval 1069862 ns, Max Jitter 69928 ns
Base thread (25us): Max interval 120306 ns, Max Jitter 95306 ns
On LCNC 2.9.3+bookworm, the latencies are indeed more, especially for the base thread where it seems to have almost doubled.
Both machines run the exact same hardware and config. I would like to know more about "tweak some kernel parameters to improve latency to acceptable levels". I'm unfamiliar with that.
2 years 2 weeks ago #312357 by rodw
Your PC should be fine but the mini PC's have some power saving features.
This document of mine covers a lot of this but primarillary for Mesa cards.
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
I am assuming it will be an Intel NIC but please check that out as Realtek needs a different path
Start with #21, #22 #23
If intel you may benefit from #27 (which Mesa needs)
Also the forum scripts for CPU affinity
My theory Is that Ethercat is not as stringent as Mesa because it has its own NIC drivers but you might prove Me wrong!
Time to create page: 0.076 seconds
