- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- How to connect after source code download linuxcnc and ethercat
- fly up
25 Oct 2024 01:59 #313178
by fly up
How to connect after source code download linuxcnc and ethercat was created by fly up
Hi all, I am following this method to install linuxcnc and ethercat from source and then I am not very clear about the process behind it, is there any way I can download and configure the connection using cia-402 or can I just configure the hal file to connect.
I hope to get help from all of you.
Sincerely appreciate it.
Ethercat build from source - full instructions - LinuxCNC
- bkt
- Thank you received: 114
25 Oct 2024 20:22 #313232
by bkt
Replied by bkt on topic How to connect after source code download linuxcnc and ethercat
from PART3 of that post really is all clear ,,,, perhaps you can dowload from ethercat 1.6 etherlab repo... use that wiki than retunt i "corbett" post to complete the process ... it is all clear .... sometime when I'm very tired i find these type of instructions annoing and too hard ... but if I try and make some error, interest grow up and magically all become more clear ....
- fly up
26 Oct 2024 08:19 #313242
by fly up
Replied by fly up on topic How to connect after source code download linuxcnc and ethercat
Okay, I'll do what I can to try to solve the problem until I run into a new one.
thanks.
thanks.
- Thank you received: 4153
27 Oct 2024 19:39 #313328
Replied by rodw on topic How to connect after source code download linuxcnc and ethercat
building from source is also well documented at Etherlab etherlab.org/en_GB/home
- EtherCAT
Time to create page: 0.291 seconds
