AC Servo ball screw pitch adjustment
26 Oct 2024 10:29 #313244 by Macwolf
AC Servo ball screw pitch adjustment was created by Macwolf
Hello, I use an AC servo with an EC interface. With a normal servo you set the steps on the encoder and then enter the steps in the controller.
My question is, is this also done with the Ethercat servo? I don't have any experience with servos like this. Or is it done in the Lcnc settings?
If this is the wrong forum, please move it, thanks
26 Oct 2024 12:21 #313246 by COFHAL
Replied by COFHAL on topic AC Servo ball screw pitch adjustment
It's simple: divide the encoder resolution by the screw pitch.
26 Oct 2024 12:29 #313247 by Macwolf
Replied by Macwolf on topic AC Servo ball screw pitch adjustment
thanks but where is this entered? in the encoder but under which category? Homing
26 Oct 2024 12:47 #313249 by COFHAL
Put in hal file setp cia402.1.velo-scale XXXXX. XXXfor velocity mode or setp cia402.1.pos-scale XXXXX. XXX for position mode the servo.
The following user(s) said Thank You: Macwolf
Time to create page: 0.915 seconds
