Lichuan LC20E Homing, End switches, Probing
- GDTH
10 Nov 2024 10:44 #314180
by GDTH
So i am retrofitting my Bridgeport 412 with ethercat 1kw 17bit incremental servo's (LC20E) from lichuan. I have been able to achieve a fully moving machine.I am at the stage where i want to home all axis. To achieve this i want to use the homing feature in the driver. So i am going to try rodw's homecomp to do this. I was wondering if i press the e-stop during homing does it stop the homing operation on the driver? Asking for safety reasons
Also my BP412 has a shared limit switch. I was wondering should i do this through the driver or linuxcnc? The issue i see with the driver is that it doesn't have a function for a shared limit switch. I guess i am kind of answering my own question but i am wondering how everone else is thinking about it.
Also the manual talkes about a probe function. I was wondering if someone could tell me about what the purpose of this is or for what it can used for?
Kind regards,
Andries
Lichuan LC20E Homing, End switches, Probing was created by GDTH
Kind regards,
Andries
- Leuo_
22 Sep 2025 18:09 #335297
by Leuo_
Replied by Leuo_ on topic Lichuan LC20E Homing, End switches, Probing
Hello, can you share your configuration?
I have an LC20E Drive with a 1kW motor with brake.
However, I am having problems with the motor configuration. Whenever I try to move it, the Er.201 alarm occurs. I have tried several configurations, even using Sandro's configuration, since his kit is similar to mine, but without success.
The following user(s) said Thank You: Cecco
- Cecco
22 Feb 2026 19:07 #343319
by Cecco
Replied by Cecco on topic Lichuan LC20E Homing, End switches, Probing
Hi i have the exact same problem, even when trying to jog the motor by the display and have it disconnected from ethercat, so it's probably a parameter of the servo drive. I know that's not the point of the topic but i would like to know how you managed the problem!
Time to create page: 0.209 seconds
