Beckhoff Compatibility
1 year 11 months ago #314841 by 7strideR
Hello,
I have been looking around planning my CNC conversion and it seems Beckhoff is the main choice for Ethercat.
I am planning to use the following
EK1100 Coupler
EL1018 Input
EL2008 Output
EL3048 / 68 - 0-10v Analog input
or
EL3058 - 0.4-20Mha Analog input
Now from what I understand I can use the EL3048 / 68 or EL3058 to read some potentiometers which I plan to use to override Spindle Speed and Feed Speed.
Now will I have any issues with using these? I have not come across someone else using them on Linux CNC. Is there a compatibility list or certain drivers required for these Beckhoff components?
Any tips or feedback is Appreciated
1 year 11 months ago #314849 by Grotius
Replied by Grotius on topic Beckhoff Compatibility
or
These are here : github.com/linuxcnc-ethercat/linuxcnc-et...evices/lcec_el3xxx.c
So everything should work.
Greetings.
The following user(s) said Thank You: 7strideR
1 year 11 months ago #314885 by 7strideR
Replied by 7strideR on topic Beckhoff Compatibility
Exactly what I was looking for.
Thank you
1 year 11 months ago #314904 by 7strideR
What's the odds of getting a Module not listed working? The one in question I am looking for is not listed in the Github
EL2088 - 8 Negative Outputs | Supported
EL2889 - 16 Negative Outputs | Not Supported
EL2809 - 16 Positive Outputs | Supported
Will it be possible to get this working or does it have no drivers?
1 year 11 months ago #314991 by Grotius
As long as a unsupported driver is close to a excisting driver nr, we can write some code for it so it works.
I am not very familiar with servo's, but beckhoff EL- stuff is not that hard.
Just order it, no worry's. We are here to assist.
1 year 9 months ago #318146 by dschultz
Replied by dschultz on topic Beckhoff Compatibility
I am in the middle of building an EtherCAT system using a Beckhoff EK1100 and would like to use the el6021 module to drive my spindle VFD with RS485.
I've searched the forum and seen it mentioned briefly a couple times but I can't find where anyone has got a driver working for it?
How hard would that be to accomplish?
Time to create page: 0.167 seconds
