Advice on Protectli V1210/V1211 for LinuxCNC
  • 7strideR
  • 7strideR's Avatar Topic Author
  • New Member
  • New Member
26 Nov 2024 05:07 #315274 by 7strideR
Hello everyone,I’m looking for a compact and fanless PC to use with my milling machine. Reliability is my main priority, as I want to avoid any hardware-related issues during operation.I’ve come across the Protectli V1210 and V1211 ( link here ) and was wondering if these would be a good fit for running LinuxCNC. I’m still learning about how the Linux kernel works, so I’d appreciate any advice or insights regarding compatibility.Additionally, if I opt for the Coreboot BIOS on these devices, are there any potential issues or limitations I should be aware of?Thanks in advance for your help!
The following user(s) said Thank You: endian
26 Nov 2024 17:28 #315314 by tommylight
Replied by tommylight on topic Advice on Protectli V1210/V1211 for LinuxCNC
Get a HP Z420 or Z430 or Z440, they are proven reliable, but they are huge and heavy.
But the are cheaper as they can be found only used.
Also, personally i avoid anything Nxxxx from Intel, they are way under powered for anything useful, but they will run the machine perfectly fine.
The following user(s) said Thank You: 7strideR
  • 7strideR
  • New Member
  • New Member
26 Nov 2024 19:28 - 26 Nov 2024 19:28 #315318 by 7strideR
Replied by 7strideR on topic Advice on Protectli V1210/V1211 for LinuxCNC
Hey thanks, they are pretty cheap for what it is, but the main issue is I am in Mauritius and there's not a lot of good tech that's affordable here. Importing a Tower PC will set me back about 400 USD (excluding the PC) which aint great to say the least.
My main reason with going with Protectli was the Intel® I226-V over a generic Realtek controller.
If I look at getting something like an Nuc with an I3 or I5 would that be a better option?
Last edit: 26 Nov 2024 19:28 by 7strideR.
Time to create page: 0.336 seconds
