- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Lichuan Ethercat Nema23 closed loop stepper motor XML configuration
- Ahmed.emara
03 Dec 2024 11:18 #315877
by Ahmed.emara
Lichuan Ethercat Nema23 closed loop stepper motor XML configuration was created by Ahmed.emara
hello guys
i am going to but Lichuan Ethercat Nema23 closed loop stepper motor with driver CL3-E57H
where can i find its XML configuration ?
- Tntmold
14 Jan 2025 23:04 #318987
by Tntmold
Replied by Tntmold on topic Lichuan Ethercat Nema23 closed loop stepper motor XML configuration
I have the same drive, did you solve this problem? I have an xml from lichuan that appears to be designed for use with Beckhoff software, I don't know if it will work for Linuxcnc
- ArkadiuszGr
13 Mar 2025 09:21 #323812
by ArkadiuszGr
Replied by ArkadiuszGr on topic Lichuan Ethercat Nema23 closed loop stepper motor XML configuration
Hello,
I am looking for an XML file for a Beckhoff controller, can you post the file here, I would be grateful. The file you need seems to be at this link:
forum.linuxcnc.org/ethercat/47534-etherc...e-configuration-woes
- EtherCAT
Time to create page: 0.150 seconds
