Reading seperate bits from sensors implemented in servo controller
- Felthaus
1 year 10 months ago - 1 year 10 months ago #316916
by Felthaus
Reading seperate bits from sensors implemented in servo controller was created by Felthaus
Hi
I've recently recieved my Ethercat servo controller, and have gotten this up and running with linuxcnc.
I'm trying to extract bit 0-4 in 60FD in my HAL file I'm reading the values via HAL using:
net io-status-signal lcec.0.0.io-status
The last 5 bits are I/O high/low sensor values from endstop and homing, however I cant seem to get access to these bits individually.
Am I missing something fundamental?
I've attached my entire (simple) setup as I'm still tinkering with the control via Ethercat
Last edit: 1 year 10 months ago by Felthaus. Reason: readability
- Thank you received: 4153
1 year 10 months ago #316934
Replied by rodw on topic Reading seperate bits from sensors implemented in servo controller
In your xml file, you need a complex entry to parse out the bits. SOmething like this example of mine. Don't just assume this is exactly what you want!
github.com/rodw-au/linuxcnc-cia402/blob/...t-conf-diewu.xml#L31
The following user(s) said Thank You: Felthaus, bananun
- Felthaus
1 year 10 months ago #316941
by Felthaus
Replied by Felthaus on topic Reading seperate bits from sensors implemented in servo controller
Thank you rodw, thats exactly what I was looking for!
Time to create page: 0.496 seconds
