Missing link in homing LC10E
02 Jan 2025 20:01 #317882 by stirra
Missing link in homing LC10E was created by stirra
I have my Lichuan LC10E drive and servo successfully doing internal homing, but I can't figure out how to make the Axis "Home All" button trigger it.  Setting x-home-request signal in halshow generates a homing cycle, but Axis "Home All" causes the motor to just spin quite independently of the drive homing parameters, and never completes.  The x-home-request home cycle completes, and turns on x-homed (cia402.0.stat-homed and joint-0.cia402-homing-finished), but this is also not reflected in Axis.Where does this alternate homing process get linked into Axis?  I have been trying to trace it from halui.home_all but get lost in the bowels of emc.Thanks,-- Ralph
03 Jan 2025 01:20 #317890 by rodw
Replied by rodw on topic Missing link in homing LC10E
Just looking at homing.c source and it has a reminder in a comment.
                   // docs: 'If HOME_SEQUENCE is not specified then this joint
                   //        will not be homed by the HOME ALL sequence'
Do you have a home_sequence set for all joints?
03 Jan 2025 04:19 #317898 by stirra
Replied by stirra on topic Missing link in homing LC10E
That was "a" problem but not "the" problem. I changed HOME_SEQUENCE to 1 and the behavior remains the same. I commented out all the other HOME_* parameters and still no change. There is still something else I'm missing.
The homecomp.comp file talks about joint._.request-custom-homing as selecting the custom homing process, and the joint.0.request-cia402-homing pin is net'ed to the x-home-request in your cia402_homecomp.comp, but does not get set from Home All, even when HOME_SEQUENCE is positive non-zero.
I tried to attach my files to the last post, but they seem to have vanished.  Here is another attempt.
File Name: cia402_202...2-2.comp
File Size:11 KB
File Name: cia402_202...02-2.hal
File Size:2 KB
File Name: cia402_202...02-2.ini
File Size:4 KB
File Name: cia402_hom...2-2.comp
File Size:16 KB
File Name: ethercat-c...02-2.xml
File Size:2 KB
10 Jan 2025 23:32 #318671 by stirra
After many hours of studying homing.c, cia402.comp, cia402_homecomp.comp and various forum posts, I finally found the last key to making LC10E drive homing work.  Here is my summary of all the changes needed to RodW's example custom homing configuration.  I can now click "Home All" in Axis and have it do a proper mode 6 home.  It still leaves all the axes with "H" in the preview window (rather than the round "survey marker" symbol), but MDI works and everything else seems to function normally.
Changes to get Lichuan LC10E homing working:
1. cia402.comp line 240
      change (statusword >> 10) to (statusword >> 12)
2. ethercat-conf.xml
      add to pdo 1600 section the lines:
           <pdoEntry idx="6098" subIdx="00" bitLen="8"  halPin="home-mode" halType="u32"/>
           <pdoEntry idx="6099" subIdx="01" bitLen="32" halPin="home-hi-speed" halType="u32"/>
           <pdoEntry idx="6099" subIdx="02" bitLen="32" halPin="home-lo-speed" halType="u32"/>
           <pdoEntry idx="609A" subIdx="00" bitLen="32" halPin="home-acc" halType="u32"/>
           <pdoEntry idx="2005" subIdx="24" bitLen="16" halPin="home-timeout" halType="u32"/>
3. cia402.hal
       after loadrt's add lines:
           setp lcec.0.0.home-mode 34
           setp lcec.0.0.home-hi-speed 50000
           setp lcec.0.0.home-lo-speed 50000
           setp lcec.0.0.home-acc 100000
           setp lcec.0.0.home-timeout 5000
      after # homing signals change nets x-home* to:
           net x-home-request joint.0.request-cia402-homing   cia402.0.home joint.0.index-enable
           net x-homing       joint.0.is-cia402-homing       cia402.0.stat-homing
           net x-homed       joint.0.cia402-homing-finished  cia402.0.stat-homed
4. cia402.ini
       in [joint_0] be sure:
           HOME_SEQUENCE = 0 (or whatever sequence number is appropriate)
           HOME_USE_INDEX = YES
           HOME_SEARCH_VEL = 0
           HOME_SEARCH_VEL = 1 (or any non-zero value)
I hope this helps somebody else.
-- Ralph
The following user(s) said Thank You: rodw, COFHAL, onceloved, zmrdko
10 Jan 2025 23:34 #318672 by stirra
Forgot to say that the lcec.0.0.home-mode 34 should be changed to the home mode you want. 34 is just handy for testing without external switches connected (34 just returns to index).
16 Jan 2025 04:43 #319088 by dschultz
Replied by dschultz on topic Missing link in homing LC10E
Can this arrangement (servo drive internal homing) be used together with absolute multi-turn encoders on a dual motor gantry?
I'd like to use the multi-turn encoders to get away from home switches if possible...
17 Jan 2025 15:52 #319189 by zmrdko
Replied by zmrdko on topic Missing link in homing LC10E
Thank you for sharing findings.
I am trying to achieve the same for Delta B3 drives.
i have questions regarding two points:
-  did you download this component from github.com/dbraun1981/hal-cia402/ and manually compiled and installed it?
4. cia402.ini
           HOME_SEARCH_VEL = 0
- here is HOME_SEARCH_VEL stated two times - maybe one should be HOME_LATCH_VEL?
26 Jan 2025 15:42 #319893 by trisa25
Replied by trisa25 on topic Missing link in homing LC10E
I tried your config in mode 34 but instead of finding the index pulse it just zeroes the current position.
Although after that if I unhome a joint and then home it again it goes to the initial postion (even multiple turns if it was moved that much).
I have also tried with other homing modes but it results in the same situation.
Kind regards
15 Jun 2025 00:01 - 15 Jun 2025 00:03 #330290 by tar_san
Replied by tar_san on topic Missing link in homing LC10E
I tested your attached files (including install attached cia402, cia402_homecomp files, successfully) in current LinuxCNC.
with LC10E - EEPROM version V1.04
Power on is OK, Jog each axis is OK,
But X axis cannot stop when I pressed [Home All] button.
In Halshow window, cia402.0.opmode = 8 always.
What am I missing ?
Does anyone know any update for it ?
Last edit: 15 Jun 2025 00:03 by tar_san.
16 Jun 2025 11:43 #330344 by tar_san
Hello everyone.
I need help for homing LC10E.
I've read cia402.comp and cia402_homecomp.comp ( the latest version )
1)
This line was commented out in last commit in cia402_homecomp.comp Line 217.
//customH[joint_num].request_custom_homing = 1;
2)
In HAL,
net x-home-request joint.0.request_custom_homing => cia402.0.home
I think cia402.opmode doesn't change to homing mode(6) because of it.
Should I use older version of cai402_homecomp to get driver-homing work?
(if in this situation, which version should I use ? )
Time to create page: 0.288 seconds
