kollmorgen AKD2G driver
21 Jan 2025 15:45 - 21 Jan 2025 15:47 #319574 by mat1370
kollmorgen AKD2G driver was created by mat1370
Hello everyone,
Has anybody worked with kollmorgen drivers with linuxcnc?
I have this error: Ethercat synchronisation error when i run linuxcnc.
I attached my xml, hal, and ini file. slave 0 is a moons driver which works correctly with this config.
slave 1 is the kollmorgen driver akd2g singel axis, which is not working.
File Name: ethercat-conf.xml
File Size:3 KB
File Name: lathehal.hal
File Size:3 KB
File Name: latheini.ini
File Size:2 KB
Last edit: 21 Jan 2025 15:47 by mat1370.
21 Jan 2025 16:28 #319575 by tommylight
Replied by tommylight on topic kollmorgen AKD2G driver
Moved to "EtherCAT" section.
18 Jun 2025 16:36 #330455 by gordon.h.keller
Replied by gordon.h.keller on topic kollmorgen AKD2G driver
Hi -- did you have any luck sorting this out? I am not working with linuxcnc, but I am having a similar error with the akd2g + ethercat in ros2 and was wondering if there was a common thread.
18 Jun 2025 17:59 #330460 by endian
Replied by endian on topic kollmorgen AKD2G driver
hello,
Some time ago, Sebastian did the config ..
Time to create page: 0.401 seconds
