Issue with Access - "pin is not writable" Error when using setp
1 year 9 months ago #319993 by Ri
Hello everyone,I'm currently facing an issue while trying to write to the pin
cia402.4.controlword
using the
setp
command in my configuration. Despite the documentation indicating that this pin should be set to read-write by default, I am receiving the error message:"pin 'cia402.4.controlword' is not writable."Here are some details about my setup:
  • I have verified the HAL configuration and ensured that the pin is defined correctly.
  • The EtherCAT configuration appears to be set up properly, with the relevant PDO and SDO entries.
  • The drive is in a state that should allow writing to the control word.
I would appreciate any insights or suggestions on how to resolve this issue. Has anyone else encountered a similar problem? Any help would be greatly appreciated!Thank you!
1 year 9 months ago - 1 year 9 months ago #320002 by Aciera
isn't 'cia402.n.controlword' an output pin? (you can't setp output pins)
Last edit: 1 year 9 months ago by Aciera.
1 year 9 months ago #320060 by Ri
According to the documentation, the control word is transmitted from the controller to the driver. What should it be? (I checked, and both with out and in I get the same error: not writable.)
1 year 9 months ago - 1 year 9 months ago #320062 by Hakan
controlword is an output pin, not writable.
Here is a small example of how you connect the cia402 component
github.com/dbraun1981/hal-cia402/tree/main/example
If it still doesn't work after that, we need to see your hal and ethercat-conf.xml files.
Last edit: 1 year 9 months ago by Hakan.
1 year 8 months ago #320603 by Ri
How should the control word be written and transmitted if it is not a writable pin? I need to write and transmit the control word; how can I do this if it is not writable through HAL? This is a valuable instruction that the driver must execute :(
1 year 8 months ago - 1 year 8 months ago #320627 by Aciera
It's an output pin of the cia402 component so the cia402 component writes the control word to lcec
#from cia402 to servo(ethercat) net x-controlword         cia402.0.controlword => lcec.0.0.cia-controlword
Last edit: 1 year 8 months ago by Aciera.
1 year 8 months ago #320650 by rodw
You need to share more about what you want to achieve. Sounds like you are going about things the wrong way...
cia402.comp is an interface between Linuxcnc joints and the ethercat cia402 servo drive.
1 year 8 months ago #320739 by Ri
where then in Linux are these signals generated, how to register them for a specific driver And where is the PLC of the machine written?
1 year 8 months ago #320755 by Aciera
You need to connect the relevant signals in your .hal file as in the example linked in the post above.
Not sure which PLC or which machine you are referring to.
1 year 8 months ago - 1 year 8 months ago #320779 by Hakan
The cia402 component generates the necessary signalling with the drive's controlword pin.
It has the logic to do state changes and other things required by cia402. Therefore, we don't bother about that, it is all handled by the cia402 component. We just use the cia402 component.
If you want to go your own way, and do the signalling yourself to the drive you write to the drive's controlword lcec.0.0.controlword.
But that is just unnecessary, use the cia402 component instead, connect it as in the example.
You can check the source code for the cia402, it is where the example is.
Last edit: 1 year 8 months ago by Hakan.
Time to create page: 0.071 seconds
