- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Issue with Access - "pin is not writable" Error when using setp
- Ri
28 Jan 2025 15:09 #319993
by Ri
Issue with Access - "pin is not writable" Error when using setp was created by Ri
Hello everyone,I'm currently facing an issue while trying to write to the pinusing thecommand in my configuration. Despite the documentation indicating that this pin should be set to read-write by default, I am receiving the error message:"pin 'cia402.4.controlword' is not writable."Here are some details about my setup:
cia402.4.controlwordsetp- I have verified the HAL configuration and ensured that the pin is defined correctly.
- The EtherCAT configuration appears to be set up properly, with the relevant PDO and SDO entries.
- The drive is in a state that should allow writing to the control word.
- Thank you received: 2164
28 Jan 2025 18:00 - 28 Jan 2025 18:05 #320002
Replied by Aciera on topic Issue with Access - "pin is not writable" Error when using setp
isn't 'cia402.n.controlword' an output pin? (you can't setp output pins)
Last edit: 28 Jan 2025 18:05 by Aciera.
- Ri
29 Jan 2025 07:37 #320060
by Ri
Replied by Ri on topic Issue with Access - "pin is not writable" Error when using setp
According to the documentation, the control word is transmitted from the controller to the driver. What should it be? (I checked, and both with out and in I get the same error: not writable.)
- Hakan
- Thank you received: 454
29 Jan 2025 09:25 - 29 Jan 2025 09:26 #320062
by Hakan
Replied by Hakan on topic Issue with Access - "pin is not writable" Error when using setp
controlword is an output pin, not writable.
Here is a small example of how you connect the cia402 component
github.com/dbraun1981/hal-cia402/tree/main/example
If it still doesn't work after that, we need to see your hal and ethercat-conf.xml files.
Last edit: 29 Jan 2025 09:26 by Hakan.
- Ri
04 Feb 2025 13:05 #320603
by Ri
How should the control word be written and transmitted if it is not a writable pin? I need to write and transmit the control word; how can I do this if it is not writable through HAL? This is a valuable instruction that the driver must execute
04 Feb 2025 17:41 - 04 Feb 2025 17:44 #320627
It's an output pin of the cia402 component so the cia402 component writes the control word to lcec
#from cia402 to servo(ethercat)
net x-controlword cia402.0.controlword => lcec.0.0.cia-controlword
Last edit: 04 Feb 2025 17:44 by Aciera.
- Thank you received: 4142
04 Feb 2025 20:20 #320650
Replied by rodw on topic Issue with Access - "pin is not writable" Error when using setp
You need to share more about what you want to achieve. Sounds like you are going about things the wrong way...
cia402.comp is an interface between Linuxcnc joints and the ethercat cia402 servo drive.
- Ri
05 Feb 2025 12:58 #320739
by Ri
where then in Linux are these signals generated, how to register them for a specific driver And where is the PLC of the machine written?
05 Feb 2025 15:24 #320755
You need to connect the relevant signals in your .hal file as in the example linked in the post above.
Not sure which PLC or which machine you are referring to.
- Hakan
05 Feb 2025 19:01 - 05 Feb 2025 19:07 #320779
by Hakan
The cia402 component generates the necessary signalling with the drive's controlword pin.
It has the logic to do state changes and other things required by cia402. Therefore, we don't bother about that, it is all handled by the cia402 component. We just use the cia402 component.
If you want to go your own way, and do the signalling yourself to the drive you write to the drive's controlword lcec.0.0.controlword.
But that is just unnecessary, use the cia402 component instead, connect it as in the example.
You can check the source code for the cia402, it is where the example is.
Last edit: 05 Feb 2025 19:07 by Hakan.
- EtherCAT
Time to create page: 0.323 seconds
