EtherCAT + lcec + cia402 + PID on A6-1000EC in velocity control mode
1 year 8 months ago - 1 year 8 months ago #320505 by hellvetica
Hi, i'm trying to make my servo spin through ethercat and I can't seem to get it moving.This is the kit:
www.omc-stepperonline.com/a6-series-1000...67-a6-ec1000h2a1-m17
I have a simple example without linuxcnc gui, just a .hal file and a ethercat-conf.xml. I can read the feedback values like current encoder position and velocity but I can't make the servo move. When i run the hal file with
halrun -T -kf simple.hal
The drive enables and the fan starts spinning but the servo doesn't even hold position.
note: This one has a brake that I disabled with an external power supply. I can spin the motor with my hand.
I'm new to ethercat in general so any help would be appreciated.
Last edit: 1 year 8 months ago by hellvetica.
1 year 8 months ago #320507 by hellvetica
Also this might be relevant:
ethercat slaves returns
0 0:0 PREOP + AS715N_sAxis_V0.10
1 year 8 months ago #320581 by onceloved
You can add me on discord, my username is onceloved.cn I can use TeamViewer to remotely configure for you
The following user(s) said Thank You: besriworld, hellvetica
1 year 8 months ago #320916 by hellvetica
Thank you @onceloved !
It turned out to be a wiring issue
1 year 8 months ago #321040 by vizavadsky
@hellvetica Looks like I have same or very similar issue. What exactly was wrong with wiring in your case?
1 year 8 months ago #321139 by Martin.L
Have you guys figured out how to auto tune this servos?
Time to create page: 0.281 seconds
