Issue with LinuxCNC Pins showing zero
20 Feb 2025 11:37 #322048 by mc_cubus
Issue with LinuxCNC Pins showing zero was created by mc_cubus
Hello Everyone,
I'm have an IFC2411 confocal sensor (Micro-Epsilon) on my EtherCAT network. The sensor is recognized and appears in OP state:
0  0:0  OP  +  ECOMODUL
1  0:1  OP  +  PD4-Ex-E-65-1 EtherCAT Drive (CoE)
2  0:2  OP  +  ECAT-2513 4-Port EtherCAT Junction(IN/OUT1)
3  0:3  OP  +  ECAT-2513 4-Port EtherCAT Junction(OUT2/OUT3)
4  0:4  OP  +  IFC2411
I can do an SDO read of 0x6000:01 and get non-zero distance values—proving the sensor is physically measuring and returning data internally:
ethercat upload -p 4 0x6000 0x01 --type uint32
0x001d6fe3 1929187
The ethercat pdos -p 4 says:
SM0: PhysAddr 0x1000, DefaultSize 1024, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize 1024, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize    0, ControlRegister 0x64, Enable 1
SM3: PhysAddr 0x1818, DefaultSize   24, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 ""
    PDO entry 0x6000:01, 32 bit, ""
  TxPDO 0x1a30 ""
    PDO entry 0x6010:01, 32 bit, ""
  TxPDO 0x1a80 ""
    PDO entry 0x6030:01, 32 bit, ""
  TxPDO 0x1ae0 ""
    PDO entry 0x7000:01, 32 bit, ""
  TxPDO 0x1ae8 ""
    PDO entry 0x7001:01, 32 bit, ""
  TxPDO 0x1af0 ""
    PDO entry 0x7002:01, 32 bit, ""
However, in LinuxCNC’s HAL pins (e.g.
lcec.0.IFC2411Sensor.ifc2411-distance
), the value stays at 0.
halcmd show pin lcec.0.IFC2411Sensor
Component Pins:
Owner   Type  Dir         Value  Name
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-counter ==> ifc2411-counter
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-distance ==> ifc2411-distance
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-frequency ==> ifc2411-frequency
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-intensity ==> ifc2411-intensity
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-shutter ==> ifc2411-shutter
    37  s32   OUT             0  lcec.0.IFC2411Sensor.ifc2411-timestamp ==> ifc2411-timestamp
    37  bit   OUT          TRUE  lcec.0.IFC2411Sensor.slave-online
    37  bit   OUT          TRUE  lcec.0.IFC2411Sensor.slave-oper
    37  bit   OUT         FALSE  lcec.0.IFC2411Sensor.slave-state-init
    37  bit   OUT          TRUE  lcec.0.IFC2411Sensor.slave-state-op
    37  bit   OUT         FALSE  lcec.0.IFC2411Sensor.slave-state-preop
    37  bit   OUT         FALSE  lcec.0.IFC2411Sensor.slave-state-safeop
The slave is defined in ethercat_conf.xml as follows:
<slave idx="4" name="IFC2411Sensor" type="generic" vid="0x00000607" pid="0x62ece209" configPdos="true">
            <syncManager idx="3" dir="in">
                <!-- Channel 1 distance 1 TxPDOMap OV1 -->
                <pdo idx="1a00">
                  <pdoEntry idx="6000" subIdx="01" bitLen="32" halPin="ifc2411-distance" halType="s32"/>
                </pdo>
                <!-- Channel 1 intensity 1 TxPDOMap OV1 -->
                <pdo idx="1a30">
                  <pdoEntry idx="6010" subIdx="01" bitLen="32" halPin="ifc2411-intensity" halType="s32"/>
                </pdo>
                <!-- Channel 1 shutter TxPDOMap OV1 -->
                <pdo idx="1a80">
                  <pdoEntry idx="6030" subIdx="01" bitLen="32" halPin="ifc2411-shutter" halType="s32"/>
                </pdo>
                <!-- Counter TxPDOMap OV1 -->
                <pdo idx="1ae0">
                  <pdoEntry idx="7000" subIdx="01" bitLen="32" halPin="ifc2411-counter" halType="s32"/>
                </pdo>
                <!-- Time stamp TxPDOMap OV1 -->
                <pdo idx="1ae8">
                  <pdoEntry idx="7001" subIdx="01" bitLen="32" halPin="ifc2411-timestamp" halType="s32"/>
                </pdo>
                <!-- Frequency TxPDOMap OV1 -->
                <pdo idx="1af0">
                  <pdoEntry idx="7002" subIdx="01" bitLen="32" halPin="ifc2411-frequency" halType="s32"/>
                </pdo>
            </syncManager>
        </slave>
The .hal file contains the following mappings:
#PDOs to HAL Pins mapping for IFC2411 Confocal Sensor
net ifc2411-distance <= lcec.0.IFC2411Sensor.ifc2411-distance
net ifc2411-intensity <= lcec.0.IFC2411Sensor.ifc2411-intensity
net ifc2411-shutter <= lcec.0.IFC2411Sensor.ifc2411-shutter
net ifc2411-counter <= lcec.0.IFC2411Sensor.ifc2411-counter
net ifc2411-timestamp <= lcec.0.IFC2411Sensor.ifc2411-timestamp
net ifc2411-frequency <= lcec.0.IFC2411Sensor.ifc2411-frequency
I have the feeling that I am overseeing something trivial and would be thankful for any kind of help!
Cheers,
20 Feb 2025 12:58 #322058 by rodw
Replied by rodw on topic Issue with LinuxCNC Pins showing zero
I suspect some SDOs need to be set. Not sure if I am reading the right manual but on P 104 it says
In object 0x1C13, it is selected which PDOs are to be transferred. The PDO mapping objects are selected.
20 Feb 2025 13:50 #322066 by mc_cubus
Replied by mc_cubus on topic Issue with LinuxCNC Pins showing zero
ok I tried setting the SDOs as specified in the manual, i.e.:
<!-- Example initCmds to map 0x1A00 to SM3 (0x1C13) -->
                        <!-- 1) Clear existing SM3 assignments -->
                        <InitCmd>
                          <Transition>PS</Transition>
                          <Comment>clear sm pdos (0x1C13)</Comment>
                          <Timeout>0</Timeout>
                          <Ccs>1</Ccs> <!-- CoE command -->
                          <Index>0x1C13</Index>
                          <SubIndex>0</SubIndex>
                          <Data>00</Data>  <!-- zero => no assigned PDOs -->
                        </InitCmd>
                        <!-- 2) Add 1A00 as the first PDO to SM3 -->
                        <InitCmd>
                          <Comment>add pdo 0x1A00 to sm3</Comment>
                          <Ccs>1</Ccs>
                          <SubIndex>1</SubIndex>
                          <Data>1a00</Data>  <!-- This is the hex index of the PDO (0x1A00) -->
                        </InitCmd>
                        <!-- 3) Set the new count of assigned PDOs to 1 -->
                        <InitCmd>
                          <Comment>download pdo 0x1C13:00 index => 1</Comment>
                          <Ccs>1</Ccs>
                          <Data>01</Data>  <!-- 1 assigned PDO in SM3 -->
                        </InitCmd>
Now, when running linuxcnc I get:
Waiting for component 'lcec' to become ready..........................Failed to execute SDO download: Input/output error
LCEC: slave 0.IFC2411Sensor: Failed to execute SDO download (0x1c13:0x00, size 1, byte0=0, error -5, abort_code 06010002)
LCEC: failed to configure slave 0.IFC2411Sensor sdo 1c13:00
LCEC: slave 0.IFC2411Sensor: Failed to execute SDO download (0x1c13:0x01, size 2, byte0=26, error -5, abort_code 00000000)
LCEC: failed to configure slave 0.IFC2411Sensor sdo 1c13:01
LCEC: slave 0.IFC2411Sensor: Failed to execute SDO download (0x1c13:0x00, size 1, byte0=1, error -5, abort_code 00000000)
I suspect that the Sensor comes up with a default (locked) PDO assignment, since ethercat pdos -p 4 says:
ethercat pdos -p 4
  TxPDO 0x1a00 ""
  TxPDO 0x1a30 ""
  TxPDO 0x1a80 ""
  TxPDO 0x1ae0 ""
  TxPDO 0x1ae8 ""
  TxPDO 0x1af0 ""
And also with $ ethercat upload -p 4 0x1C13 0x00 --type uint8 one can see which PDOs are assigned to the 0x1C13 object and all are already assigned to it.
I am trying to figure out if the problem lies on the Sensor side or I did something wrong with LinuxCNC configuration.
26 Feb 2025 10:45 #322678 by mc_cubus
Ok, apparently I just needed to restart the Sensor couple of times in a row and now I started to see the data. The topic may be closed.
Cheers,
Time to create page: 0.108 seconds
