Thank you for your response. These are the printout messages from two different systems, respectively.
First System:
[ 238.627879] EtherCAT: Requesting master 0...
[ 238.627885] EtherCAT: Successfully requested master 0.
[ 238.639567] EtherCAT 0: Domain0: Logical address 0x00000000, 450 byte, expected working counter 27.
[ 238.639571] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 450 byte, type LRW at ffff91a4e6ce0318.
[ 238.640138] EtherCAT 0: Master thread exited.
[ 238.640141] EtherCAT 0: Stopping EoE thread.
[ 238.640157] EtherCAT 0: EoE thread exited.
[ 238.640159] EtherCAT WARNING 0: EoE External processing required!
[ 238.640160] EtherCAT 0: Starting EtherCAT-OP thread.
[ 239.249213] EtherCAT 0: Domain 0: Working counter changed to 21/27.
[ 239.291171] EtherCAT 0: Slave states on main device: PREOP, SAFEOP.
[ 239.572573] EtherCAT 0: Slave states on main device: PREOP, OP.
[ 239.860401] EtherCAT 0: Slave states on main device: PREOP, SAFEOP, OP.
[ 240.181272] EtherCAT 0: Slave states on main device: PREOP, OP.
[ 240.251335] EtherCAT 0: Domain 0: Working counter changed to 24/27.
[ 244.842333] EtherCAT WARNING 0-main-0: Slave did not sync after 5000 ms.
[ 244.852890] EtherCAT 0: Domain 0: Working counter changed to 27/27.
[ 244.886478] EtherCAT 0: Slave states on main device: SAFEOP, OP.
[ 245.167387] EtherCAT 0: Slave states on main device: OP.
Second System:
[ 3248.220047] EtherCAT: Requesting master 0...
[ 3248.220054] EtherCAT: Successfully requested master 0.
[ 3248.225443] EtherCAT 0: Domain0: Logical address 0x00000000, 406 byte, expected working counter 21.
[ 3248.225447] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 406 byte, type LRW.
[ 3248.225471] EtherCAT 0: Master thread exited.
[ 3248.225474] EtherCAT 0: Stopping EoE thread.
[ 3248.225489] EtherCAT 0: EoE thread exited.
[ 3248.225490] EtherCAT 0: Starting EoE thread.
[ 3248.225559] EtherCAT 0: Starting EtherCAT-OP thread.
[ 3248.225732] EtherCAT WARNING 0: 16 datagrams UNMATCHED!
[ 3248.299560] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.315523] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.339530] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.356219] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.371609] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.391524] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.409001] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.423525] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.439516] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.455500] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.471503] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.487610] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.503529] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.519501] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.535504] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.551521] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.567541] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3248.583503] EtherCAT WARNING 0-6: Other mailbox protocol response for eoe0s6.
[ 3250.223357] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3251.223374] EtherCAT WARNING 0: 10 datagrams UNMATCHED!
[ 3252.223350] EtherCAT WARNING 0: 16 datagrams UNMATCHED!
[ 3253.223370] EtherCAT WARNING 0: 10 datagrams UNMATCHED!
[ 3254.223357] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3255.223368] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 3256.223343] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 3257.223350] EtherCAT WARNING 0: 16 datagrams UNMATCHED!
[ 3258.223347] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 3258.720269] EtherCAT ERROR 0-6: Timeout after 10000 ms while setting state OP.
[ 3258.727412] EtherCAT 0: Slave states on main device: PREOP, SAFEOP.
[ 3259.223344] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3260.223352] EtherCAT WARNING 0: 16 datagrams UNMATCHED!
[ 3261.223364] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 3262.223349] EtherCAT WARNING 0: 8 datagrams UNMATCHED!
[ 3263.223381] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3264.116265] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[ 3264.223353] EtherCAT WARNING 0: 12 datagrams UNMATCHED!
[ 3265.227471] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 3265.287422] EtherCAT ERROR 0-3: Mailbox error response received - Unknown error reply code 0x0000.
[ 3265.287431] EtherCAT WARNING 0-3: Invalid mailbox response for eoe0s3.
[ 3265.327467] EtherCAT ERROR 0-3: Mailbox error response received - Unknown error reply code 0x0000.
[ 3265.327474] EtherCAT WARNING 0-3: Invalid mailbox response for eoe0s3.
[ 3266.227344] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 3267.227351] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 3268.227347] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3269.227348] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3270.033265] EtherCAT ERROR 0-6: AL status message 0x002D: "No Sync Error".
[ 3270.036267] EtherCAT 0-6: Acknowledged state SAFEOP.
[ 3270.227348] EtherCAT WARNING 0: 14 datagrams UNMATCHED!
[ 3270.435372] EtherCAT 0: Slave states on main device: OP.
[ 3271.227376] EtherCAT WARNING 0: 10 datagrams UNMATCHED!
[ 3273.239359] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 3274.239353] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3275.243359] EtherCAT WARNING 0: 8 datagrams UNMATCHED!
[ 3276.243376] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 3278.247366] EtherCAT WARNING 0: 10 datagrams UNMATCHED!
(Repeated warnings about unmatched datagrams...)
Based on a cursory review, I speculate that the first system might be using a compatible version of the EtherCAT protocol with the slave devices (drivers), whereas the second system might be utilizing a newer version of the protocol that is not fully compatible with the older version supported by the slave devices.
Additionally, the "UNMATCHED" warnings seem to persist throughout the operation in the second system, indicating potential issues with data packet matching or communication synchronization. Note that I haven't included all the printouts, but the frequent occurrence of these warnings suggests ongoing communication issues.
