- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- LinuxCNC using Ethercat on Raspberry Pi5 controlling Stepperonline A6 Servo
- Tim1
05 Mar 2025 19:54 #323309
by Tim1
LinuxCNC using Ethercat on Raspberry Pi5 controlling Stepperonline A6 Servo was created by Tim1
Hi I can't get the servo drive from SAFEOP to OP mode due "EtherCAT ERROR 0-0: AL status message 0x001B: "Sync manager watchdog""
cnc@raspberrypi:~$ sudo ethercat state INIT
cnc@raspberrypi:~$ sudo ethercat state PREOP
cnc@raspberrypi:~$ sudo ethercat state SAFEOP
cnc@raspberrypi:~$ sudo ethercat state OP
cnc@raspberrypi:~$ sudo ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: SAFEOP
Flag: +
Identity:
Vendor Id: 0x00400000
Product code: 0x00000760
Revision number: 0x00005608
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3079639242 0 0
1 MII down closed no - - - -
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/256, TX: 0x1400/256
Supported protocols: CoE, FoE
General:
Group: AC Servo Driver
Image name:
Order number: ANCTL AS760N Servo Driver
Device name: AS760N_sAxis_V0.10
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
cnc@raspberrypi:~$ dmesg | tail -20
[ 9664.358899] EtherCAT ERROR 0-0: SDO download 0x1C32:01 (2 bytes) aborted.
[ 9664.358905] EtherCAT ERROR 0-0: SDO abort message 0x08000022: "Data cannot be transferred or stored to the application because of the present device state".
[ 9664.358907] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 9664.402879] EtherCAT ERROR 0-0: SDO download 0x1C33:01 (2 bytes) aborted.
[ 9664.402886] EtherCAT ERROR 0-0: SDO abort message 0x08000022: "Data cannot be transferred or stored to the application because of the present device state".
[ 9664.402889] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 9760.555095] EtherCAT ERROR 0-0: SDO download 0x1C12:01 (2 bytes) aborted.
[ 9760.555100] EtherCAT ERROR 0-0: SDO abort message 0x08000022: "Data cannot be transferred or stored to the application because of the present device state".
[ 9760.555102] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 9760.595087] EtherCAT ERROR 0-0: SDO download 0x1C13:01 (2 bytes) aborted.
[ 9760.595094] EtherCAT ERROR 0-0: SDO abort message 0x08000022: "Data cannot be transferred or stored to the application because of the present device state".
[ 9760.595097] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 9865.955283] EtherCAT 0: Slave states on main device: INIT.
[ 9872.951304] EtherCAT WARNING 0-0: Aborting SDO request, slave is in INIT.
[ 9872.967344] EtherCAT WARNING 0-0: Aborting SDO request, slave is in INIT.
[13760.889546] EtherCAT 0: Slave states on main device: PREOP.
[13765.925570] EtherCAT 0: Slave states on main device: SAFEOP.
[13782.411825] EtherCAT ERROR 0-0: Failed to set OP state, slave refused state change (SAFEOP + ERROR).
[13782.411909] EtherCAT ERROR 0-0: AL status message 0x001B: "Sync manager watchdog".
[13782.412843] EtherCAT 0-0: Acknowledged state SAFEOP
Device: Main
State: SAFEOP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Image name:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
- Hakan
- Thank you received: 454
05 Mar 2025 22:01 #323317
by Hakan
Replied by Hakan on topic LinuxCNC using Ethercat on Raspberry Pi5 controlling Stepperonline A6 Servo
Check this thread forum.linuxcnc.org/ethercat/54965-stepperonline-a6-servo maybe there is a solution
- Tim1
05 Mar 2025 22:43 #323318
by Tim1
Replied by Tim1 on topic LinuxCNC using Ethercat on Raspberry Pi5 controlling Stepperonline A6 Servo
I checked that thread and I haven't seen anything to address the Sync manager Watchdog.
- EtherCAT
Time to create page: 0.093 seconds
